Sign-in / Sign-up
Ps3 HDMI to DVI PC Monitor HELP!
  • Console Gaming
  • DVI
  • Monitors
  • HDMI
  • Video Games
Last response: in PC Gaming
October 26, 2012 2:05:10 AM
I bought a HDMI to DVI adapter and used my HDMI Cord from my TV plugged it in to PC Monitor with adapter nothing will work 480p-720p-1080i-1080p no picture will show up i tried every setting 1 by one.
My Monitor is HP S2031 HDCP compatible.
Im thinking the Adapter is Broken.
More about : ps3 hdmi dvi monitor
October 26, 2012 4:41:12 AM
You say that you plugged the cable into your monitor, but you never said you plugged it into your PS3 on the other end. Not that I think that's the problem, anyway. I once had a set-top box which would connect via HDMI to my TV, but if I used an HDMI DVI cable (HDMI out from the set-top and DVI in to the TV), no picture would show up. I never figured out why, but maybe some devices just don't work with some cables.
m
l
November 13, 2012 7:23:45 PM
Adapter was Faulty bought another one and works perfect.
m
l
