Dear People!
I just had a question i would like to ask in regards to overclocking. I have gotten my system with the specs below running my Athlon XP @ 2100+ and 2200+ the system will run stable for a week or so with the temperature indicated below, but what usually happens is my power supply will usually blow up or go up in smokes after a week. I have tested a few power supplys but nothing that is expensive but all power supplys seems to go up in smokes i have tested 4 types but same thing happens. Would it be that i need a really good power supply that can keep a stable voltage or is it of another problem?
My system specs are as follows:
Athlon XP 2000+ (139 FSB x 12.5 @ 1.85V)(Using Arctic silver 3 & Volcano 7 + ThermalTake Fan)
Epox 8RDA+ (2 x Kingmax DDR400 256Mb @ 2.77V - 133%)
Radeon 9700 Pro Gigabyte (OC @ 350Mhz GPU & 640Mhz Memory + extra cooling heatsinks)
on a 400Watt rated powersupply
CPU is at 34 degrees and system at 32 degrees.
