http://www.modthebox.com/review91_1.html
thats the baybus I have, chose the baybus or the Y-adapter, no reason to have both. If you want to run your fans at ALL times then go w/ the Y adapters. I like the baybus, it's dual voltage, high is 12v and low is adjustable via a potentiometer, I have the low set to 7v. It's got connectors on the back, you stick the wire in and tighten a screw which clamps the wire in. When you put the fan on low the LED shines blue, when on high it shines red.
If you have a case w/ a rounded front bezel it probably won't work, my case resembles the LianLi Aluminum cases, and the baybus works great!
<P ID="edit"><FONT SIZE=-1><EM>Edited by voidedwarrenty on 01/14/03 10:52 AM.</EM></FONT></P>
