Any twit can put many very large fans on their system. The
trick is to have fans that do their job only when needed.I live in Melbourne Australia and the ambient temperature can
reach 44 deg celcius as it did about a week or two ago. The
four fans(x2) in both of my systems 80mm Thermaltake(1&2) were spinning at over 5000revs abient at 42deg celcius.But when
it is cooler one can hardly hear them.The processor temps.
MBM5 (diode)were 56degC and 58 degC.The other trick is to replace that pissy little fan in the power supply with a decent grunty fan (ThermaltakeII) and use the thermistor
on the heat-sink of the power supply and replace the pot.
that comes with the above with a 50k variable potentiometer
and then you can set the base speed of the fan to what your
environment requires.
avandonk
avandonk
