Tom's Hardware > Forum > Systems > Compaq > after battery change: still 162 system options not set
Forum Systems : Compaq - after battery change: still 162 system options not set
Archived from groups: alt.sys.pc-clone.compaq (More info?)
dear cpq gurus,
i installed a nvidia vga card to an 'old' deskpro ex 1.0 ghz. after the
first reboot i got: 162 system options not set. i changed the battery and
still have this message. what should i do next. upgrade the bios ???
thanx alot
tim
Sponsored Links
Do you set the system options? The 162 error is telling you that the CMOS
settings are corrupt, i.e. they have changed in such a way that they need to be
set again... Ben Myers
On Thu, 28 Apr 2005 15:26:51 +0200, "Tim Moor" <tim.moor@nospam.com> wrote:
>dear cpq gurus,
>thanx alot
>tim
Reply to Anonymous
i have the solutions.. i have encountered same problem.. but luckily i solved it with patient :)
after message 162 system options not set appears.. i let it run for about 15 minutes and it sets by it own.. and lastly it boots up.. but you need a RomPaq to update your bios need to create a boot diskette if you changed your original hard drive coz need to reconfigure the boot hardrive... or else it wont boot from HD.
Reply to Anonymous
There are 581 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
