Archived from groups: alt.cellular.verizon (More info?)
I just tried out the the v620, and it doesn't work on my laptop -
something about bus mode incomparability. Does anyone know if there's
any evdo card that I will be able to use?
>It depends on your laptop.
>If you are using an IBM ThinkPad T41, there is a discussion on
>EVDOforums.com that steps you through getting it to work:
>http://www.evdoforums.com/about149.html
>There are some problems with power to the PCMCIA on specific Dell
>models too.
