Sign-in / Sign-up
need some HELP!!! with 2500+ on A7N8X
  • CPUs
  • Windows XP
  • Overclocking
March 29, 2003 12:54:58 AM
my system:
XP 2500+ Barton
asus A7N8X (non dlx)
wd 80 gig 8mb cache
512mb kingston hyper x cl.2 ddr370
geforce 2 MX400
PSU Q-teq 400W dual fan gold
i got my barton running at 169x12.5=2114Mhz cpu volt. 1.725
the weird thing is if i try to set my fsb at 170 it wont post. and my system just freezes. the only thing it was doin was blowin air. so i reset cmos and set it at the above settings and everything is working fine.
but i would like to know why it is it wont post when i set my fsb to 170.
my other bios settings:
cpu interface: optimal
memory freq. : optimal
memory timings: optimal
i'm happy with the current overclock but i want to know how far i can go. so any suggestions on what i'm forgettin r welcome.
THANKS
btw. is there a program to set the fsb while running in xp?
More about : 2500 a7n8x
March 29, 2003 10:59:10 AM
now i got another problem :s... the thing is it wont load windows normally.right after it says windows is loading, my screen turns black and my monitor goes in standby. right now i'm in safe mode and i cant find any problems... i already tried system restore but that didnt work. NEED HELP
March 29, 2003 11:51:17 AM
ok i know a bit more now. there was an error on startup:
the following boot-start or system start drivers failed to load:
AmdK7
Fips
does that mean my drivers arent good for my barton?
March 29, 2003 1:42:51 PM
that means that you pushed your processor too hard and have corrupted some windows files, you may need to reinstall windows.
March 29, 2003 2:05:47 PM
i dont think thats the case....the weird thing is after i unplugged my comp. for a while, its running great again.. pretty weird.thanks anyway. but can some one answer my other q.???
a c 168 à CPUs
a c 351 K Overclocking
March 29, 2003 2:42:58 PM
With what you've posted the only weak link I see is the video card, have you considered going to a more aggressive card.
<b><font color=purple>Details, Details, Its all in the Details, If you need help, Don't leave out the Details.</font color=purple></b>
March 29, 2003 3:26:01 PM
ya i am goin to get another but not right now.. i want to wait for a while so that i have the money.so u think i cant overclock more cus of my videocard. hhmmmm.thanks for pointing that out to me. that sucks. :p
March 31, 2003 12:47:34 AM
If you get into windows, try running Prime95. They have a test that is really accurate. If you get a single error, then your processor is clocked too high/not cooled well enough. I thought I was stable at 12.5x175, but I wasn't. I'm now at 11x189 I'm stable, though slower.
XP 2500+ Barton @ 2241Mhz
A7N8X Dlx
2x512MB Corsair PC3200
MSI GF3Ti 500
16x DVD-ROM
2x80GB 7200RPM Maxtor
Onboard audio
March 31, 2003 1:30:31 PM
thanks i'll give that a shot. btw i think its the temp. cus my highest was 57C.. a bit high i think. but at the asus probe it says 47C. but i trust the bios more. so that means i need to get a new case with lots of cooling.
April 1, 2003 6:21:56 PM
Not a new case.
Adding one or two fans to your current case may help a bit... unless your case temps aren't very high. If they aren't high a better HSF will cool your CPU much better.
My dual-PSU PC is so powerfull that the neighbourhood dims when I turn it on :eek:
April 3, 2003 1:24:47 AM
I dont think your card is holding you back from OC over 169. I have almost the same setup, and I'm using a Radeon 7000 (my 9700 is in RMA status), and my FSB is 182.
April 3, 2003 2:27:37 PM
That card can handle insane AGP speed. My GeForce2 MX is running on an 89MHz AGP bus. That would need a 222.5 MHz FSB in his case.
But talking in performance that card is indeed the slowest of all components.
