This is a re-post of what i posted in the motherboards section. I figure in here it may be just as useful... Maybe it'll be viewed by Asus or something.. eh.. here goes...
I have been having the weirdest problems with my computer. Here's the situation, any help would be GREATLY appreciated as it may be saving me a good $300(aus). This is gonna be a pretty lengthy post coz i really do need some serious help, i usually can fix anything and everything wrong with pc's and i built the system myself, eg i know my way around pc's. So armed with that knowledge, dig deep and see if you can assist me, at all...
- A7V running in Jumperfree mode
- 1100mhz Tbird
- Thermaltake SuperORB
- 128MB TwinMOS RAM (one stick)
- Leadtek Winfast GeForce2 MX (32MB) (was damaged but i repaired it and it's been tested and works perfectly in other systems and my own Before this problem... therefore it's not causing the problem) (but i will explain this shortly)
- Soundblaster LIVE! Value
- Realtek Network Card (10base)
- AOpen HQ45 Case (250w power supply)
- Yamaha 8x4x24 CDRW
- Teac 32x CDROM
- Seagate 15GB UltraATA-66 5400RPM HDD Master (connected with 80pin shielded cable to the ATA100 connection)
- Fujitsu 6GB Slave (unknown specs... model# MPD3064AT) (connected with 80pin shielded cable to the ATA100 connection)
- Running Windows 98SE
Ok, now you know the specs, here's the situation leading up to the problem. I had been playing around with mIRC and some a**holes decided to send me virii and stuff, i discovered the Sub7 trojan for example. So i backed up my necessary stuff to cd's and went to dos to format, i then realised that i had one image file (to be burnt) that i absolutely needed, but i couldn't get into windows as the virii had stuffed things up... So i decided i would simply delete everything from the HDD manually and then reinstall windows. I started the process and when it finally came to deleting the C:\windows\ folder it took an exeedingly long time so i left it to do it and went to bed, i awoke in the morning and the system had frozen, so i thought little of it and reset. This is where i encounterred my problem, it made a series of continuous long beeps... I checked my manual and it said it was No DRAM installed or Detected. So i fiddled with my ram and changed the socket it was in, and turned the comp back on... Now there were no beeps at all, and the comp didn't even pass the POST (eg no beep). It just sat there with the HDD activity led flashing solidly (eg staying on) and when i restarted, the led went off but there was no response from the computer, it just sat there.
So now i was worried, i unplugged all peripherals, eg HDD's, Floppy, CD's, Sound & Network card... and retried. But the same thing happened, nothing. No beeps, nothing.
So i checked everything on the motherboard and couldn't see any visible change. I figured perhaps it was my BIOS that had been wiped or something similar by a virus as i had heard there was a new virus that did that... So i changed my jumpers around a bit and took it out of jumperfree mode, and then turned it on. I was back where i started, it just did the series of beeps meaning no RAM. So i went to a friend's house and tried all my components in his machine. The RAM worked perfectly (in his A7Pro) and so did the Video card and other peripherals. So i can narrow it down to the CPU or Mobo. But i assume that if it beeps at all, the cpu has to be working... There are no visible markings on either the cpu or the mobo, suggesting no burnouts. Hence my confusion. I have rebuilt the system from scratch 4 times now (taken EVERYTHING out, including the cpu and fan and plugs and mobo from the case) and it's still not working.
Here's the other possibility, the Graphics Card was blown about 2 weeks prior to this problem. I attempted to unlock my clock multiplier on my cpu, never touching anything but the cpu, and ran the system bare on top of the case (had to take the mobo out of the case to get better access to the cpu) and when i turned it back on, there was an arc in the AGP slot and smoke spilled from the card. I checked it, after standing there shaking in fear of the thought of $500 down the drain, and found that there were two pins missing the gold plating and they had lifted off the board, there was also some black burn marks around them, but after a while i realised i could try to repair them and did so... Don't laugh, but i carefully superglued the pins down and cleaned them off, i stuck it back in and it worked perfectly, even tho the AGP slot had small melted parts where the pins had been blown, and it worked perfectly under full load up until this problem.
If you guys have any questions, PLEASE email me at theaudiophile01@hotmail.com (it's my only internet email addy while the comp is dead and i have to use the school comps) or just post back, whichever is easier. You can't imagine how much i need your help, i have tried everything i can think of. My post has been as detailed as i could make it, if you need anymore info please just ask, i will try to help.
Thanks again...
Helplessly, Fraser MacFarlane (aka The Audiophile) (contact me on icq also @ 31578119)
