A case without adequate air intakes is going to run hot no matter what you do fan wise.
The golden rule is "the same intake area as occupied by the exhaust fans"... an 80mm exhaust fan needs the equivalent of an 80mm square opening to let air in. That can be in the form of several smaller openings, one big one or grille work so long as the areas more or less match up. With less intake than exhaust you get a pressure drop inside the case which limits the amount of cooling air to the components.
Check for slots/openings underneath the front plastic cover, look for grille-like openings under the front edge. If they aren't there, you really should either look into a new case or modify your existing one.
There are some fairly good, medium priced, cases here:
<A HREF="http://www.aopen.com/products/housing/default.htm" target="_new">http://www.aopen.com/products/housing/default.htm</A>
--->It ain't better if it don't work<---
