Tom's Hardware > Forum > Overclocking > Cooler and Heatsinks > Need Help With water
I'M Having a hard time getting the water in my water unit..
How do I get the water in? my setup is:
Criticool Watertank>Eheim 1250 pump>sfwiftechmc5000 cpu>swiftech mc50 gpu>blackIce Radiator>back to reservoir.
Do I or can I put the pump in a bucet of water first? can someone direct me to a detailed webpage to help me or answer my dilema here. I need help Pleeeeease!
Sponsored Links
well you can put the a tube leading to the pump's input into a water-reservoir and let it run, but you will have to connect it to your system... hmmm, ideally you should have a bleed/fill valve on your reservoir
<b>I'm
just
taking
up
space.
Heheheh, and you thought I was done</b>
Reply to error_911
how about raising your reservoir above the rest of the system and just filling it with water?
<A HREF="http://www.planettribes.com/allyourbase/ayb2.swf" target="_new">411 UR 84$E R 8E10NG 2 U$</A>
Reply to LtBlue14
There are 1186 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
