Archived from groups: alt.sys.pc-clone.compaq (More info?)
I have a Presario 6000 (6rpxe1) with a 220 watt psu. The fan is gone on my
ti4200 graphics card and was considering upgrading it. I'd like to go with a
second tier type card (6800 or x700) but have been told I'll need a better
psu.
Anyone know a psu that will fit and handle any proprietary needs for the
mobo? Are their any modifications that I may need to perform? Thanks in
advance.
Actually i meant a 6600 not a 6800.
"Gordon" <notnow@no.com> wrote in message
news:0lCoe.21213$IX4.20907@twister.nyc.rr.com...
>a second tier type card (6800 or x700) but have been told I'll need a
>better psu.
> advance.
> Gordon
I can't recall the innards of a Presario 6600, but many Presarios used
oddly-shaped power supplies. If the power supply in your system does not
follow a standard form factor and you want to upgrade the wattage, consider
buying a new case with power supply and move the guts from the Presario to the
new case... Ben Myers
>>better psu.
>> advance.
>> Gordon
Take a look at www.power-on,com. They have some replacement PSU that offer
higher wattages than the OEMs.
KC
a
> psu.
> advance.
> Gordon
Thanks. Good site. However the units aren't any more powerful than what's
already in there.
Gordon
"Kevin Childers" <wildthing123@charter.net> wrote in message
news:xD1pe.15746$QX1.14407@fe06.lga...
> offer
> KC
>> my
>> with
> better psu.
>> advance.
>> Gordon
Was worth a shot, some Mfgs offer replacement PSUs that have a higher
wattage than the cheaper ones OEMs install. There are other sites out there
that may be of use, check the specs and pictures for a good fit at the
wattage you need.
KC
news:7Zfpe.7708$jU5.1881970@twister.nyc.rr.com...
> already in there.
> Gordon
> > offer
> > KC
> >> my
> >> with
> > better psu.
the
> >> advance.
> >> Gordon
