I am finally getting ADSL and I am pondered with this question: I have 2 choices of modems...Home or USB.
Apparently an USB modem connects to your USB port and doesn't require a NIC.
A Home modem does.
This is a quote from my ISP:
<i>To use a USB modem, you need to have a USB port on your PC (most modern PCs have such a port). If you do not have a USB port, then you need to install a Network Card and use the Home type modem. </i>
So, what are the differences in performance between the two? What I'm getting is a 512k up/ 128k down connection. What should I get? Advantages? Disadvantages? I am a single user and I'm not on a network.
I would definitely go for the modem for two reasons:
1) You can easily add a switch or a hub, and make your own LAN. I know you write you are a single user and not on a network. But some day you'll get another PC you want to attach to the WAN as well. Or when you have friends visiting, they can easily plug into your switch and get WAN access as well.
2) You will have no problem with drivers etc., and you can use the modem even if you run Linux.
