You should only give out email in private message because of spammers. Some actually have a search bot that will go through entire forums gleening all the email addresses! You can edit your post to delete it.
I've sent the information. Your board definately supports 100MHz bus speeds, and possibly 133MHz bus speed, by CPU auto-detection. You might need to raise your core voltage, you can do that with pins as well. And there's the possibility that it MIGHT not run at 950MHz. Most will, some won't, all require a voltage increase.
I ALWAYS recommend people test their processors on an overclocker's board before modifying them for a restricted board.
<font color=blue>Watts mean squat if you don't have quality!</font color=blue>
