I have to do a physics project, and am also tired of listening to my computer make lots of noise, so I naturally though of water cooling my pc, so I figure if i design my own water block and compare the effectivness of it vs. a standard heat sink ect... I can probably get a decent grade, I was wondering if anyone had any experience, advise or input on it, besides if it doesn't work I'll just go out and buy one... so if anyonehas any experience I'd appreciate the advice looking at these 2
http://www.overclockers.com/tips997/index04.asp
http://www.overclockers.com/tips1051/index04.asp
one specific question though, would it matter between drilling the main area in the bottom then adding a flat top, or drilling into the top and adding a thin bottom... one was done one, and one the other...
