Hi, 2 months ago, i posted a question about how to reduce fan noise. I took someone's advice and bought myself a vantec stealth fan at 21dba and 27cfm. I also bought 2 nmb fans at 15dba and 18cfm. I bought a 80 to 60mm adapter. I replaced my 60mm cpu fan with the vantec stealth and the adapter. The vantec stealth makes more noise than the nmb, but it cools my cpu a lot better than the nmb. with the vantec, my cpu is 55C while with the nmb, its 65C. I also bought a new psu from fortron-source, the 300w psu with the big 120mm fan in it, which runs at a slow speed and is barely audible. Overall, my computer is a lot quieter than it used to be, but im afraid that the temperature is too high. im now using nthe nmb fans as case fans, but they dont push enough air. should I go and buy 2 more vantec stealths to replace them?
would my case get a lot louder?
would replacing my 60mm aluminum heatsink with ah thermalright sk-7 or slk-800 or slk-900 help with the cpu cooling? which should i get? which would fit on my ecs l7vta motherboard which has no holes for screws? its running on a xp1600+.
I'm also thinking of assembling another computer, but i dont know whether or not to get a case that supports 120mm case fans. Should I? it would probably be running on a xp2400+ or above.
so far, the quietest 120mm fan that ive found is the 120mm vantec stealth at 28dba and 58cfm. i was thinking of getting 120mm fans for greater cooling, but 28dba is a lot louder than the 80mm at 21dba, and the 80mm is not completely quiet. I've found some cheap cases that support only 1 120mm fan that are only $25 with no psu, but the antec slk3700 supports one in the front and one in the back, but it has a psu and costs $73. I was thinking that the antec psu might be loud, and maybe I should buy the cheap case and get another one of those fortron-source psu with the big and quiet fan. are 120mm fans too loud?
I dont know, so confusing.
Or maybe i should just buy a cheap case that only uses 80mm fans?
someone please give me their opinion.
Thanks
Thanks
