Tom's Hardware > Forum > General Networking > Firewall > Kerio/Tiny problem
Kerio/Tiny problem
Forum General Networking : Firewall - Kerio/Tiny problem
Archived from groups: comp.security.firewalls (More info?)
Hi all,
I recently tried to upgrade from Kerio 2.15 to 4.x. On installation,
it claimed, that there was still something left from Tiny PF and I
should remove it manually. Well, indeed, there is an entry in Windows'
add/remove panel named "Tiny Personal Firewall 2.0.15A (221001)". But
I can neither remove it nor do anything with it.
I suspect it to be a forgotten registry entry, but searching the reg
for *tiny* was to no avail, nor did RegCleaner find anything. Does
anyone have an idea, where this entry might be stored?
TIA :-)
Cheers
Peter
The Bat! v.2.11 Beta/6, on Win98, 4, 10, build 2222, PII at 200MHz, 64 MB RAM
Sponsored Links
Download and install tweak iu system tweaking program.
This program comes with the Win9.x resource kit. However,
you can find it invidually through search engines.
Tweak IU has a tab for removing unwanted programs from
your install/uninstall control panel feature. Do note
it does not uninstall programs but simply deletes an
entry from displaying. This will not cure your problem,
however. You do have a registry entry somewhere.
Be careful using Tweak IU. It is a very powerful program
which will customize your Windows in many ways. Be sure you
understand how it works, what it does and what results
will happen if you use a feature.
Run your regedit.exe and look for not only "tiny" but
also the name of the company which makes that firewall.
Very often you will find registry entries under the
name of the company, not the name of the software.
Search for all possible "terms" associated with Tiny
Firewall and eventually you will locate all entries.
Check your Windows\Temp directory for installer information
related to Tiny Firewall. Get rid of it, if found. Many times
problems come about because of lingering installer files,
such as used by the MSI installer. Almost all temporary
files can be deleted safely, but it is a good practice
to look them over, just in case. Gozilla is an example.
Gozilla creates temp files which should NOT be deleted.
Illogical but Gozilla installs some of its needed files
in Windows\Temp directory.
Microsoft's resource kit is available for free at their
website. Very hard to find but it is there. Run a search
engine for the resource kit, you might find a complete
package for downloading.
If not, Microsoft maintains a ftp site with the resource
kit and keeps the ftp URL well hidden. I think they have
forgotten it is there.
ftp://ftp.microsoft.com/services/ [...] 98/Reskit/
There is a challenge. What you see on that ftp page is the
entire resource kit, but split into directories as installed
by default for the original CD ROM retail version. You have
to create all those directories / child directories on your
hard drive, then download all file contents for each directory.
Takes a long time to do this but well worth it. Once done,
run "setup.exe" and the resource kit will be installed with
a selection on your start menu, under "accessories" link.
Years back, that resource kit had $80 price tag.
Lot of very powerful tools in that resource kit, including
Tweak IU. Microsoft quit distributing this kit because it
allows users to modify windows in ways Microsoft later
determined, they did not want, like killing off MSIE, AOL,
MSN and other advertising media included in Win9.x versions.
Your final cure will be to find all registry entries
related to Tiny Firewall. This will take a bit of
effort and time. Keep at it, you will prevail.
Purl Gurl
Reply to Anonymous
"Peter Meyns" <peterNOSPAM@meynsweb.com> wrote in message
news:177100711.20040523204019@devnull.meynsweb.com...
> Hi all,
For what it's worth, it's my experience that you have to uninstall
either to install the other.
Reply to Anonymous
Thank you, that did it. I could remove the entry with Tweak UI and
install Kerio 4.16. I immediately found that I cannot really use it,
probably due to my slow processor (200 MHz), but at least I could try.
Now I'm back to Kerio 2.15. :-)
Thanks for all the information. I'll see what else Tweak UI can do for
me.
Kind regards
Peter
Reply to Anonymous
Right. Tiny PF was uninstalled long ago. The only thing left was this
entry in the add/remove panel, and I could now remove it with Tweak
UI.
Kind regards
Peter
Reply to Anonymous
There are 730 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
