Archived from groups: comp.security.firewalls (More info?)
Hi,
I accidentally switched off my computer before windows had finished
closing down. When I restarted it the disc check came up with a load
of errors which were reported to have been 'truncated' and then
desktop appeared as per normal.
I did another reboot cos some things weren't working right and now the
only problem I have is with kerio.
It's as if kerio has started from scratch & I've been informed
everytime a program wants to access the net - and created rules
appropriately.
I keep getting informed that such-and-such from the net wants to
access different ports (particularly 1025 & 1026) and I used to have a
'block all' rule which (I think) prevented this.
The trouble is (if its not already apparent) that I don't know much
about computers in general and kerio in particular - I may even still
have the block all rule but in case its 'gone' could anyone tell me
what it is please? preferably in nice easy steps!
Thanks in advance,
John Latter
Model of an Internal Evolutionary Mechanism (based on an extension to homeostasis) linking Stationary-Phase Mutations to the Baldwin Effect.
http://members.aol.com/jorolat/TEM.html
"John Latter" <jorolat@msn.com> wrote in message
news:rp36b0hr0jsas8dulc8gcp7trf5k59mjq1@4ax.com...
> Hi,
> appropriately.
Save your configuration (Administration->Miscellaneous->Save) when
ever you make changes, so that you can reload a version, when things
go wrong. I also maintain a text file version, e.g.
My tabbed file looks a real mess here, ask if you have questions.
You can get the addresses of your DNS servers by running ipconfig /all
This firewall is still being tweaked, but I haven't had any viruses in 4
weeks.
Run Active Ports (http://www.ntutility.com) to locate 'listening ports' and
block
incoming TCP to them (except the Kerio listening ports, of course)
Initially log everything and set alerts on things that you're not sure of.
Use a good anti-virus (e.g. AVG7 - www.grisoft.com) and check your system
for infections every day.
>Subject: Re: Problem with Kerio - please help!
>From: "Alan Illeman" illemann@surfbest.net
>Date: 25/05/2004 16:16 GMT Daylight Time
>Message-id: <10b6or411ne88b7@news.supernews.com>
>> Hi,
>> appropriately.
>> what it is please? preferably in nice easy steps! >
>Filter Rules Both == In\Out
>Description Protocol Local Remote Owner Status
>DNS primary UDP(Both) [any port] [DNS primary]:[53] SERVICES.EXE Permit
>DNS secondary UDP(Both) [any port] [DNS secondary]:[53] SERVICES.EXE
>Permit
>POP3 UDP/TCP(Out) [Any Port] [Surfbest POP3]:[110] MSIMN.EXE Permit
>NNTP TCP(Out) [Any Port] [Supernews]:[119] MSIMN.EXE Permit
>SMTP TCP(Out) [25] [Surfbest SMTP]:[25] MSIMN.EXE Permit
>HTTP TCP(Out) [Any Port] [Any Address]:[80] IEXPLORE.EXE Permit
>Internet Explorer (cache) UDP(Out) [Any Port] [127.0.0.1]:[Any Port]
>IEXPLORE.EXE Permit
>Outlook Express (cache) UDP(Out) [Any Port] [127.0.0.1]:[Any Port]
>MSIMN.EXE Permit
>Inbound 127.0.0.1 UDP/TCP(In) [Any Port] [127.0.0.1]:[Any Port] Any
>Application Deny
>Outlook Express (HTTP) TCP(Out) [Any Port] [Any Address]:[80] MSIMN.EXE
>Permit
>FTP control TCP(Both) [Any Port] [Any Address]:[21] IEXPLORE.EXE Permit
>FTP data TCP(Both) [Any Port] [Any Address]:[20] IEXPLORE.EXE Permit
>AVG Update downloader TCP(Both) [Any Port] [AVG1]:[80] AVGINET.EXE
>Permit
>AVG Update downloader TCP(Both) [Any Port] [AVG2]:[80] AVGINET.EXE
>Permit
>PING [8] Echo Request ICMP(In) [Any Port] [Any Address] Any Application
>Permit
>PING [0] Echo Reply ICMP(Out) [Any Port] [Any Address] Any Application
>Permit
>Rest of the ICMP messages ICMP(Both) [Any Port] [Any Address] Any
>Application Deny
>Bootp & TFTP UDP(Both) [67-69] [Any Address]:[Any Port] Any Application
>Deny
>Ports 135,137-9,445,1026 TCP(In) [135,137-9,445,1026] [Any Address]:[Any
>Port] Any Application Deny
>Ports 500,1027 TCP(In) [500,1027] [Any Address]:[Any Port] Any
>Application Deny
>Host Process for win32 TCP(In) [Any Port] [Any Address]:[Any Port]
>SVCHOST.EXE Deny
>weeks.
>block
Thanks for replying Alan but I really am hopeless at this. I thought I might
have saved my settings some time ago and in the process of reloading I managed
to lose all of my rules.
Consequently I'm starting from scratch again but I don't know which to deny so
I'm permitting everything.
Could you tell me how to create a "Block All" rule please?
John Latter <jorolat@msn.com> wrote in message news:<rp36b0hr0jsas8dulc8gcp7trf5k59mjq1@4ax.com>...
> Hi,
> closing down.
> appropriately.
Unless a Kerio expert has a better idea, it sounds like some of your
files have become corrupted. If Kerio was operating at the time you
powered down your computer, one or more of its files may have been
open, and so now they're in a state Kerio can't use. Probably the
simplest solution would be to completely uninstall Kerio, including
erasing the contents of the Kerio folder, then reinstall. You would
have to re-train Kerio at this point, but it should retain all it
learns.
In article <20040525121525.05832.00001851@mb-m03.aol.com>,
jorolat@aol.com says...
John, no offense here at all, but if you're that uncomfortable with
Kerio's rules and such, you might be much better off with another
firewall that takes care of all those details for you. Sygate is a
pretty good one. At the bottom of this page there's a download link for
the free version: http://smb.sygate.com/buy/download_buy.htm. It works
well...
X-No-archive: yes
"John Latter" <jorolat@aol.com> wrote in message
news:20040525121525.05832.00001851@mb-m03.aol.com...
[snip]
might
managed
deny so
You don't really want a rule to block all, do you? When you install Kerio
2.1.5
it suggests some rules, and you can modify/add to those. Also use some/all
the
rules that I provided. I was 'hopeless' at first, but I just read and
studied and
improved.
Additionally to the rules I suggested, make sure that
Administration->Advanced->
Miscellaneous->Log into file - is enabled. Also enable "Log Packets
Addressed
To Unopened Ports" and "Log Suspicious Packets"
dslreports has a file "section 2_5_1_Kerio and pre-v3_0 PFW" providing some
tips for using Kerio 2.1.5, but some of them don't work for me. For example,
it
suggests that after the permitted ICMP rules, you place a rule that denies
all types.
It also suggest that the order of the rules is very important, and again, I
disagree.
Keep off the internet until you are completely satisfied with the integrity
of your
firewall, and stay with newsgroups for a while. I stayed off for 3 days -
but I'm
a slow learner ;-) Better to have too many rules, at first. Set them to log
the results
and study the log file: Firewall Status -> Logs -> Firewall Log. Before you
rightclick
on the log file window, to clear it, save the contents of c:\Program
Files\Kerio\
Personal Firewall\filter.log - to another text file, as a permanent record.
Some other firewalls may be 'better' but what ever firewall you use, you'll
eventually have to understand the protocols. I started out with Kerio 4
(even
bought a licence) - but now prefer Kerio 2.1.5
You can also email me if you wish ( replace illemann with alananne ).
"Alan Illeman" <illemann@surfbest.net> wrote in
news:10b6or411ne88b7@news.supernews.com:
<Snipola>
> weeks.
<Snipola>
For some reason I'm having difficulty with this statement. 4 weeks?
I've been internetting for about 8+ years and I have had a firewall
less than half that time.
In all that time I've only been infected once, about two months ago.
It was my own fault though. I connected to the net with an out of the
box win2k system with no firewall. But it was no big deal as it was
a test setup and I was planning on reformatting anyway.
On Tue, 25 May 2004 13:31:06 -0700, Kerodo
>well...
No offense taken Kerodo!
In fact I had thought of returning to ZoneAlarm (if it's still free)
cos I had it once before but I might give Sygate a go instead.
John Latter
On Tue, 25 May 2004 17:37:14 -0400, "Alan Illeman"
<illemann@surfbest.net> wrote:
>X-No-archive: yes
>[snip]
>might
>managed
>deny so
>2.1.5
>the
>studied and
>improved.
>Addressed
>it
>all types.
>disagree.
>of your
>but I'm
>the results
>rightclick
>Files\Kerio\
>(even
Thanks Alan! If I had the time I might do as you suggest (I certainly
have the interest) but for the moment I think I'll try a simpler
firewall.
John Latter
>> Hi,
>> closing down.
>> appropriately.
>learns.
I never thought of trying that N1POP - if it doesn't work then I'm
gonna try Sygate!
John Latter
"Skywise" <into@oblivion.nothing.com> wrote in message
news:_iPsc.10340$be.9631@newsread2.news.pas.earthlink.net...
> <Snipola>
> > weeks.
> <Snipola>
> Perhaps I'm just lucky.
Maybe. I've been using Win95 since its inception without a firewall
until March of this year - and never had a virus. A newer machine,
newer software, and voila - all manner of problems. Prior to March
I didn't really know what a firewall was!
newsnh7b094b65dbkq99lg48jp9lt6op7kc42@4ax.com...
> firewall.
You'll have to learn sometime ;-)
Look for these FAQs posted every 2 weeks in comp.answers, news.answers
and other ngs, both maintained by Uri Raz
On Wed, 26 May 2004 09:01:13 -0400, "Alan Illeman"
>> firewall.
>(1)
>TCP/IP Resources List
>This posting contains a list of various resources (books, web sites,
> FAQS, newsgroups, and useful net techniques) intended to help a newbie
> to learn about the TCP/IP suite of protocols.
> Primary indexed copy - http://www.private.org.il/tcpip_rl.html > Secondary indexless copy -
>http://www.faqs.org/faqs/internet/tcp-ip/resource-list/index.html
>(2)
>TCP/IP Applications FAQ
>http://www.private.org.il/mini-tcpip.faq.html
>Good luck
Thanks for the links Alan!
John Latter
