I'm building my first pc, planning on using primarily for gaming (Can't get enough of those great Skyrim graphics I've been seing on PCs). I've got some of the parts lined up after research, but what do you experts think as far as my choices so far? I'd like to be playing Skyrim at some pretty high graphics settings, and I know I'll be playing Chivalry a lot as well (if that matters)
Case
* Thermaltake Chaser MK-1
(http://www.newegg.com/Product/Product.aspx?Item=N82E16811133191)
I know $120 is a lot to spend on a case, but I'm pretty set on the Chaser since it looks to be amazing at cooling and aesthetically as well.
PSU
* Raidmax Hybrid 2 RX 730SS
(http://www.newegg.com/Product/Product.aspx?Item=N82E16817152036&Tpk=%u2022%09Raidmax%20Hybrid%202%20RX%20730SS)
Motherboard
* Foxconn A9D
(http://www.newegg.com/Product/Product.aspx?Item=N82E16813186199)
CPU
* AMD Athalon II X4 640 Quad Core
(http://www.newegg.com/Product/Product.aspx?Item=N82E16819103871)
RAM
* G.SKILL Ripjaws Series 8GB
(http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314)
Video Card
* PowerColor AX7850
(http://www.newegg.com/Product/Product.aspx?Item=N82E16814131472&Tpk=%u2022%09PowerColor%20PCS%2b%20Radeon%20HD%207850%20AX7850%202GBD5-2DHP)
HDD
* Western Digital Caviar Green WD15EZRX
(http://www.newegg.com/Product/Product.aspx?Item=N82E16822236380&Tpk=%u2022%09Western%20Digital%20Caviar%20Green%20WD15EZRX%201.50%20TB%203.)
Optical Drive
* DVD Burner
The total is roughly $650 right now, and I'm trying to stay within that price range. Thanks guys!
Case
PSU
Motherboard
* Foxconn A9D
CPU
RAM
Video Card
* PowerColor AX7850
HDD
Optical Drive
* DVD Burner
