im looking at the thermalright slk 900u series, these seem to offer the best cooling potential at the lowest noise, whats everyone else recomend?
im going to drop a 92mm fan @ 1800 rpm's on the heatsink, itll blow 35 cf/m will this be sufficient? i like it cause its quiet, only 25 db's
anything better? id like to keep temps around 40ish, 50 under full load is acceptable
and im not looking at watercooling, but i will of course be using arctic silver,
ive also considered sanding the heatsink face just too polish it up, anyone know if this significantly aids cooling?
"Going to war without France is like going hunting without an accordion."
- Gen. (Ret) Norman Schwartzkopf
