New EPOX 8RDA+, xp2500+ and System/MB Temp is VERY HI!, like 38-41C!
CpuTemp holds 7-8C above Sys/MB temp, but never seen sys/mb temp so hi, even with case open ( closed it can go >42c). Checked previous posts on 8rda+ and there are reports of wierd temp reporting on these mobos...
I think i've found the problem, but now how do i fix it!
Its the nForce MCP-T/MCP chip! Experimenting with where i should place a case fans i noticed that this MCP-T chip is VERY HOT!. If i set a case fan blowing directly on the MCP-T chip the Sys/MB temp goes DOWN FAST, like within 30-45 seconds the system temp falls from 40C to 32-33C! Cputemp falls also.
The MCP-T chip is definitely the hot spot and heat generator on this mobo...
There is no heat sink in this chip, and the system temp diode/thermister MUST be in/around the mcp-t chip due to the relatively quick reaction from fan and temp readings.... So, whats the best fix?
Actually for this situation perhaps a side case fan blowin right down on the mcp-t chip would probalby be very good, but till then...
(and the normal position of side case fans isnt quite right as the MCP-T chip is pretty far off center - would require a custom case mod...)
Two solutions come to mind...
1. Mount a case fan inside the case with a couple a angle brachets so the fan blows directly on the mcp-t chip - preliminay tests settin a case fan inside blowin on the chip with the case closed holds sys temp to 33-35C - might be acceptable?
2. Stick a heat sink on the mcp-t chip with AS thermal adhesive? I'd have no problems stickin a HS on it perminitely or even makin my own thermal adhesive as i've read you can easily make your own adhesive mixin 50/50 blend thermal paste and std epoxy. Perm fixutre wouldnt bother me at all, but would just a passive HS do the job? Might need HS and fan too!
An there's what looks like painted logo and text in the mcp-t chip - should one try and get that off before stickin a HS onit?
3. Custom case mod - Am thinkin this might be the easiest - mount a fan in the case perfectly above the chip and then drill some neat ventalation holes in side of the case... custom fan positioning and hole drilling might just provide a prefect mix of circulation and fresh air (just don't set the box flat up against a desk!)
Hmmm... Its a problem! And definitely the MCP-T chip as the source!
Any other 8RDA+ users have this problem?
Suggestions?
Suggestions?
