Tom's Hardware > Forum > General Networking > Firewall > ZoneAlarm 5.0 problems
Forum General Networking : Firewall - ZoneAlarm 5.0 problems
Archived from groups: comp.security.firewalls (More info?)
I posted earlier about my problems with 5.0...
I cannot use CHKDSK... when I check the option to reboot and do...
it does not run.... my PC shows the usual boot info... HD info etc
etc... then the windows startup screen THEN it says WINDOWS SHUTING
down... then it boots up... it's kind of double booting... note my
PC worked fine before I installed the 5.0 Suite... after the
problems I reinstalled an image of my HD... and my system worked
fine... so I reinstalled 5.0 Suite... the same problem occurred...
SO I reinstalled the image again... the PC was fine and then I
decided to tried 5.0 PRO this time... again I could not run
CHKDSK...
Does anyone have a fix for this... desides the obvious ;)
I noticed that folks at the ZoneLabs forums are having similar
problems...
http://forum.zonelabs.org/zonelabs [...] e.id=11711
http://forum.zonelabs.org/zonelabs [...] e.id=12067
=____________________________-
////// (____) RKBA _____|
(/////___________________(_____|
Giovanni Lentini (/ /( )/o/)_/)_/)_/)_/)
(/ 0 /_\__))
gio@rkba.net (/ /)
(/ 0 /)
(/____ /)
Sponsored Links
On Thu, 27 May 2004 02:17:13 -0500, Bob Horvath wrote:
I also ran into a ZA problem. I didn't find any problems with 5.0
at first, until I checked my Comcast dl'd speed, and saw that it went
from 3400kbs to 1700 kbs. After much testing, it turned out to be ZA
5.0, Went back to 4.5 and speed is back up to 3400 kbs.
>CHKDSK...
>problems...
>http://forum.zonelabs.org/zonelabs/board/message?board.id=inst&message.id=11711
>http://forum.zonelabs.org/zonelabs/board/message?board.id=cfg&message.id=12067
> (/ 0 /_\__))
> gio@rkba.net (/ /)
> (/ 0 /)
> (/____ /)
Reply to Anonymous
There are 515 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
