Tom's Hardware > Forum > Overclocking > CPUs > Another power supply question
Forum Overclocking : CPUs - Another power supply question
Hey guys,
I have a Raidmax aluminum case. It came with a 400 watt no name PSU. My specs are...
P4 2.4c @ 3.0
ASUS p4p800dx
512 MB Geil PC4000 Golden dragon
Zalman 7000cu cooler
ATI Radeon 9500 (somtimes O/Ced)
2 Maxtor 7200 rpm 8mb cach 60 gig HD (may add a third)
2 optical drives
SB Audigy 2
Delta 66 sound card with omni studio
3 case fans
Floppy drive
I'm wodering if the PSU may limiting my over clock. If I up the voltage on my CPU to 1.6v. I can get my CPU to 3.2 and maybe higher. But it is not stable in prime 95. Sandra benchmarks run ok.
Right now I have my CPU 254FSB and only ran prime 95 for 9 minuites before I got an error. At 250FSB it can run all night with no erors. I noticed when running Prime 95 my voltags fluctuate some. My vcore is set to auto right now.
Vcore 1.488-1.504
12v 11.725-11.916
5v 5.053-5.08
3.3v 3.264-3.28
With the exception of the 5v all voltages are lower than spec. I don't notce the fans slowing down when the cdrom spins up.
What do you guys think? Is my PSU a problem?
Sponsored Links
You could always try to run your system with only your primary harddrive and non-O/Ced graphics to see if there“s a change? IMO that 12v is a bit too low.
The difference between theory and practise in practise is greater than the difference between theory and practise in theory.
Reply to Praesul
If I were you I'd get a brand 450 psu because it's just worth it, you'll get what you paid for.
I hate Computers! My P4 2.4C won't go above 3840mhz. My Sapphire 9800pro core/mem speed won't go above 490/790. I really hate computers!
Reply to scottchen
Ok thanks for the replies. I may get a new PSU. Still thinking. I can't run with one HD because I have them in raid 0.
P4 2.4c @ 3.0
ASUS P4P800 dx
Geil pc4000 2.5,3,3,6 250FSB 1:1
Radeon 9500 non-pro
2 Maxtor 60gig 7200rpm 8mb cach in raid 0
SB Audigy 2
Maudio delta 66 with omni studio
Reply to siranthony
There are 511 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
