This is purely informative as I formatted already but wondering if anyone else has this problem and if there is a working solution for the problem.
Ok so I have a Logitech Clear chat comfort usb headset.
On my one system windows7 64 the headset works fine for like 2 months then it just stopped working...
I looked for a reason why and couldnt find anything wrong, windows recognized it as being there, said drivers were installed and it was working ok(So they say!)
Tried different ports etc.
I tried it on other systems including another win7 64 bit system and the headset works fine there.
I can not set it as default or disable my hdmi audio on my ati hd5670 either.
I tried enabling/disabling none of that worked. Eventually sound stopped working completely. Yuck!
After much research seems to be a bug with usb audio that has been there since windows vista with the fix being to replace the driver with one from XP.
I dont have 64bit xp to get a driver from so I ended up formatting and reinstalling.
So my question is for future reference. Reinstalling is a real hassle and I would prefer not to repeat :/
