Xbox wired controller - left/right analog press doesn't work (on PC)
Last response: in Video Games
Usually when playing PC games,the Analog stick buttons are usually never used on PC games,also depends on what PC games you're playing since some do have compatibilty issues or are half compatible,try it out on you're 360 on games that use those buttons and if they don't work,try sending it back to the companie that made you're controller for repair or get you're money back for a another one if you recently bought it
