I have been thinking about ways to cool my cpu better than it already is and one easy cheap thing keeps popping to mind, but I'm not sure if it would work or not, so I'll run it by you guys and maybe some of you have done it already or know something I don't.
I was thinking about buying one of the mini refridgerators and just placing my whole cpu case and everything inside it. Granted you would have to get one that wouldn't frost or perhaps turn it up so it never got that cold. it wouldn't be fancy but it would serve the purpose wouldnt it? say you got it down to 40 degrees inside the fridge wouldn't that lower the system temp as well as the cpu temp say 30 degrees based on a 70 degree room temperature.
thanks for any future input.
Devin
Devin
