looking at buying this one but i dont know how effective it will be anyone got one?
THERMALTAKE AQUARIUS II Liquid Cooling System Model A1604 Complete Kit, Suitable for AMD K7, AMD K8 and Intel Celeron and P4 CPU's, Copper Radiator 86x130x89mm Copper Pipe with Staged Copper Fins, DC12volt .16amp Water pump 100x50x86mm 3pin Motherboard power connector, 1.2kg/cm2 Water Pressure, 90 L/hr Pump Speed Ceramic Bearing Blue LED Light Shows Pump Running Status, See-Through Refill Reservoir, "Intelligent" Water Tubing provides Sping insertion to avoid crimping of hose.
Intel PIV 2.4C @ 3.0G \
Asus P4C800 \
Corsair 2x512 3200LL memory \
Radeon 9600pro @ 500/700/1.35 \
SB Live 5.1 \
80G Seagate S-ATA150 \
430 Antec 1080AMG
Asus P4C800 \
SB Live 5.1 \
430 Antec 1080AMG
