Tom's Hardware > Forum > Systems > Compaq > Compaq Mainboard and Power Supply Info?
Forum Systems : Compaq - Compaq Mainboard and Power Supply Info?
Archived from groups: alt.sys.pc-clone.compaq (More info?)
I have been searching the Compaq website
http://h10025.www1.hp.com/ewfrf/wc [...] =c00009316
concerning detailed info for a TR100 motherboard and DPS-250KB-2B
Rev:02 power supply but so far nothing. Even called the support number
and was told it should be on the website but could not tell me where.
Any suggestions?
Thankyou
Steven
Sponsored Links
Did you find a power supply or solved the problem? I am helping a friend fix a 4409cl and the PS is broken on his also....
Reply to curtis0036
- 0 +
If you need the power supply and motherboard, Go buy a new case, board, and power supply and move the parts over. Unless you can find the parts for a reasonable price on Ebay. Looks like a slow machine.
Reply to gpfear
- 0 +
can you give measurement of the PSU? I think it is a micro ATX PSU.
Reply to exp328
- 0 +
278645-001 44.00
Power supply - ATX enhanced, 200 watts steady-state
You can order it from partsurfer if you really need this. The system looks so old you just might want to get a barebones kit with the right socket and move over the existing hardware
Reply to gpfear
There are 1268 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
