PS3 to Monitor no signal :(
blake1243
593
I bought an adapter to use my PS3 on my monitor. It is DVI-D Male to HDMI Female. It works when plugging HDMI from my pc into my DVI monitor... but when i try hooking my PS3 up to the monitor it gets no signal at all. Even when i hold down the power button on the PS3 to reset the video i get nothing. I prefer PC gaming but i just wanna play PS3 when my IRL friends are online you know? And i read that PS3's won't display on a monitor that doesn't support HDCP but mine obviously does.
http://us.aoc.com/monitor_displays/e2243fwk
Thats the monitor i am using.. it is 22 inch 1080p with DVI-D and HDCP. I know everthing works because the adapter will display my PC through but not the PS3. And my
PS3 works fine on my HDTV.
