Tom's Hardware > Forum > Overclocking > Motherboards > Weird problem need help
I have a Asus A7V266VM motherboard used it since 2002 Augest, I have install a Audigy and Geforce 4 MX onto it, but when I play 3D games like MAFIA, Max payne 2 etc.. the entire system crashes and requires restart, this occurs competely randomly! it could be 1 hour or 1min!
Also, during start up my Sony DVD rom is often not detected! and when i try to change cds in windows the system freezes!
I have updated my bios to the lastest version, using windows XP and a 250Watt power supply....would this effect the system?
THANKS
Sponsored Links
Welcome holliswhy!
1. This section of the forum is for advice for overclocking mobos. So you should prolly repost elsewhere in the hardware section, cuz this ain't about OCing your mobo:)
2. That's a pretty weak graphics card and newer games like MP2 are gonna make it gag unless everything (resolution, refresh rate, details)in game options is set really low.
3. That power supply is on the low side and that can cause instability issues too.
4. Is DX9 installed (I think MP2 has some DX9 code (but not sure?)
5. Have you installed newer drivers for the MX card or still using the original ones? The older drivers with newer games could also cause instability.
XP 2000+
MSI KT3 ULTRA-2 KT333
Maxtor 60GB ATA 133 7200RPM
512MB PC2700
ABIT G4 Ti4200 OTES 64MB
Win98SE
Reply to Coyote
Sounds like the PSU is not giving enough juice to the computer. Time to get a bigger one.
F-DISK-Format-Reinstal DO DA!! DO DA!!
Reply to addiarmadar
There are 1019 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
