Solved
GTA 4 FPS problem!!!
Hello,
My game GTA 4 not working properly.
The game run smoothly at highest settings. But problem is, Consider that I am driving a car in game as soon as i turn the car, the game freeze for less than a second.
It is fine for one time but it is game and it need to hit many keys with timing :o and it makes the game to freeze until i stop using keyboard!!
My computer meets the minimum requirements for the game and still there is a big trouble!! :fou: :fou:
25 answers Last reply Best Answer
More about problem
  1. What is your system specs?
  2. Assuming his computer is good enough to run highest settings, it could be things like old/bad drivers, overheating, etc... You need to provide more details than just "the game freeze for less than a second"
  3. Specs ?
  4. I copy-pasted this info form DxDiag.exe >> My specs <<
    System Information
    Time of this report: 1/11/2013, 19:54:34
    Operating System: Windows 7 Ultimate 32-bit (6.1, Build 7600) (7600.win7_rtm.090713-1255)
    Language: English (Regional Setting: English)
    System Manufacturer: System manufacturer
    System Model: System Product Name
    BIOS: BIOS Date: 08/25/09 15:51:10 Ver: 08.00.14
    Processor: AMD Athlon(tm) II X2 240 Processor (2 CPUs), ~2.8GHz
    Memory: 2048MB RAM
    Available OS Memory: 2048MB RAM
    Page File: 1383MB used, 2711MB available
    Windows Dir: C:\Windows
    DirectX Version: DirectX 11
    DX Setup Parameters: Not found
    User DPI Setting: Using System DPI
    System DPI Setting: 96 DPI (100 percent)
    DWM DPI Scaling: Disabled
    DxDiag Version: 6.01.7600.16385 32bit Unicode
    DxDiag Notes
    Display Tab 1: No problems found.
    Sound Tab 1: No problems found.
    Sound Tab 2: No problems found.
    Input Tab: No problems found.
    DirectX Debug Levels
    Direct3D: 0/4 (retail)
    DirectDraw: 0/4 (retail)
    DirectInput: 0/5 (retail)
    DirectMusic: 0/5 (retail)
    DirectPlay: 0/9 (retail)
    DirectSound: 0/5 (retail)
    DirectShow: 0/6 (retail)
    Display Devices
    Card name: AMD Radeon HD 6670
    Manufacturer: Advanced Micro Devices, Inc.
    Chip type: AMD Radeon Graphics Processor (0x6758)
    DAC type: Internal DAC(400MHz)
    Device Key: Enum\PCI\VEN_1002&DEV_6758&SUBSYS_25061462&REV_00
    Display Memory: 1782 MB
    Dedicated Memory: 1014 MB
    Shared Memory: 767 MB
    Current Mode: 1600 x 900 (32 bit) (60Hz)
    Monitor Name: Generic PnP Monitor
    Monitor Model: 2036
    Monitor Id: AOC2036
    Native Mode: 1600 x 900(p) (60.000Hz)
    Output Type: HD15
    Driver Name: aticfx32.dll,aticfx32.dll,aticfx32.dll,atiumdag.dll,atidxx32.dll,atiumdva.cap
    Driver File Version: 8.17.0010.1151 (English)
    Driver Version: 9.2.0.0
    DDI Version: 10.1
    Driver Model: WDDM 1.1
    Driver Attributes: Final Retail
    Driver Date/Size: 9/28/2012 07:13:28, 935424 bytes
    WHQL Logo'd: Yes
    WHQL Date Stamp:
    Device Identifier: {D7B71EE2-2418-11CF-AD73-0C05BEC2C535}
    Vendor ID: 0x1002
    Device ID: 0x6758
    SubSys ID: 0x25061462
    Revision ID: 0x0000
    Driver Strong Name: oem18.inf:ATI.Mfg.NTx86.6.1:ati2mtag_NI:9.2.0.0:pci\ven_1002&dev_6758
    Rank Of Driver: 00E62001
    Video Accel: ModeMPEG2_A ModeMPEG2_C
    D3D9 Overlay: Not Supported
    DXVA-HD: Not Supported
    DDraw Status: Enabled
    D3D Status: Enabled
    AGP Status: Enabled
  5. Play the game on low. This PC can't handle high settings
  6. Wow, and Athlon X2 and 2GB of RAM. Not nearly enough to max GTA IV. I'm actually shocked it runs at all.
  7. What config I need to run it on max settings?
  8. GTA IV is a very poorly optimized game for PC. Even powerful rigs are known to have problems running it. It is surprising the game runs at highest settings on your machine. I have a Core 2 Duo @ 2 GHz and 4GB RAM with GeForce 9300GS and that doesn't meet the minimum requirements.
    Make sure your game is patched to the latest version.
    Just a note, you just have to go into Computer > System Properties to get your system specs. You don't need to post up an entire dxdiag log.
  9. It's not entierly smooth on i5 at 4.6ghz and an oc'ed gtx 670 although adding enb doesn't slow it down
  10. Best answer selected by Shubham16feb.
  11. Please tell me you didn't do this too? ;)
  12. I play GTA IV on Very High on a ASUS GTX 680. Idon't agree that GTA IV is not optimized for the PC, as i have no problem and i get SOLID super high Frame rates in it.
    I would have did this but i didn't got the DVD! But If i had it, I would just get the DVD and explode it using nuclear bomb :sol:
  14. These are the result of benchmark tool of GTA 4:
    Statistics
    Average FPS: 27.16
    Duration: 37.12 sec
    CPU Usage: 95%
    System memory usage: 86%
    Video memory usage: 22%
    Graphics Settings
    Video Mode: 800 x 600 (56 Hz)
    Texture Quality: Low
    Render Quality: Low
    View Distance: 1
    Detail Distance: 29
    Hardware
    Microsoft Windows 7 Ultimate
    Video Adapter: AMD Radeon HD 6670
    Video Driver version: 8.17.10.1151
    Audio Adapter: Speakers (High Definition Audio Device)
    27 FPS is still good to play the game any way. But that doesn't remain the same. When any new event occures in game, it drops down to very very low FPS.
    I just want to complete the game any how and according to http://www.systemrequirementslab.com/cyri my PC meets the min requirement!
  15. Quote:
    lol, http://kotaku.com/5101687/grand-theft-auto-iv-on-pc-is-a-little-broken
    You never tried to play the game on the PC when it came out or even a year after it's release.
    You are right but now we have the new Kepler cards which are faster. I think on the year in which GTA IV was released the 9000 series where introduced. However, that ain't a problem now, also seriously GTA V is going to be released so shouldn't we looking to upgrade the PC to meet its Specs? Well, i think my GTX 680 is enough to handle that because i spend a damn lot of my pocket money to get a GTX 680 and i ain't thinking of upgrading anytime soon. :)
  16. Quote:
    LOL, my bank account is severely depleted. XD
  17. Quote:
    I just can't understand the meaning of playing GTA IV on SLI configuration, because two 9800 GT in SLI (I don't know whether it support SLI or not i am just taking it as a example) is slower than a GTX 680. I mean, who would want to play it in old cards in SLI?
  18. Best answer
    As for your problem Shubham16feb,
    (I'm sorry I can't help you if you run Windows XP, because i have Windows 7, but if you run Windows 7 or Windows Vista in your PC, I can help you out.
    1. Go to start and open Run,
    2. Type in 'msconfig' and press enter, a System Configuration window will open
    now.
    3. Now, select the third tab 'Services'.
    4. Now, there will be a huge list ( :D ) out of that you will have to find - Windows Event Log and Windows Event Collector.
    5. Now you will have to UN - tick both.
    6. Now press Apply and then OK.
    7. What 7.? you are good to go, ENJOY :D.
  19. Quote:
    Best thing to do is un-install and put the install dvd in the microwave.
    And die by putting your head in to check whether it is ready to eat or not!!!
  20. What difference does taking off event logging do?
  21. Event logging tracks keyboard movements which slows down the game.
  22. Way to necro.
    Pretty sure that's not what event logging does.
  23. Shubham16feb said:
    Hello,
PC gaming Games FPS Video Games
