Tom's Hardware > Forum > Systems > Gateway2000 > Power supply question
Archived from groups: alt.sys.pc-clone.gateway2000 (More info?)
Last week I installed a new Radeon 7000 AGP video card in my old Gateway
P3-450. I reported that I couldn't get it to work very well in 16 bit color
mode.
Today, I downloaded and installed Rage3d tweak tool. With this tool, I am
able to lower the clock speeds on the video card. When I lower the clock
speeds, all my video problems are solved...no more pixilation, in any color
mode. And text is very clear in 16 bit mode now.
Does this mean that my power supply may be too weak? It's only 200w I
believe.
Thanks
Sponsored Links
Power supply is one possibility. Another might be that the ATI tweak tool
allows you to increase the scan frequency and/or change the resolution to
something more pleasant... Ben Myers
>mode.
>believe.
>Thanks
Reply to Anonymous
> tool allows you to increase the scan frequency and/or change the
> resolution to something more pleasant... Ben Myers
The only settings I changed with the tweak tool were the clock settings for
the video card. I had to lower the memory clock setting about 12Mhz to get
the card to work well. I left the core clock speed setting alone.
I'm really curious why I had to do this to get the card to work in Win2k and
XP, but not in Win98...the card works fine in 98 without changing a thing.
Reply to Anonymous
Good question to which probably only ATI knows the answer... Ben Myers
Reply to Anonymous
ATI has not been of much help in troubleshooting this problem. I got my
help from an ATI user forum. I was just about ready to yank this card....
Thanks
Reply to Anonymous
- 0 +
Yeah, try swapping in a 300W PSU, it can't hurt, plus will prepare you for
future upgrades. A buddy of mine had a Radeon and swapping a PSU fixed his.
Funny though, he couldn't get his to work in 98 but it worked perfect in XP,
go figure.
"BalloonKnot" <nospam@home> wrote in message
news:UPudnUGAB7-vM-jdRVn-gg@adelphia.com...
color
> mode.
color
> believe.
> Thanks
Reply to smith
There are 1111 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
