I assume you need a cooler because you bought an OEM processor.
Vantec Aeroflow is an awesome cooler, it'll allow minor overclocking, it's fairly quite also.
If you really got a hard-on for silence, the the Zalman CNPS7000A-ALCU, would be the way to go, at 20dBa, you can't hear that.
If you're looking for something that'll handle moderate overclocking, then Thermalright products, such as SP97, SLK947/900/800U, SLK900/800A, SK7. The Swiftech MCX462, is also a great heastsink. These high-end heatsinks doesn't include a fan, therefore you'll need to choose a fan, most of these heatsinks use 92mm fan, except for the 800U/800A.
-AMD Athlon64 3200+@2300mhz -GAK8N -3x512 Hynix PC3200 ram@192mhz 2.5-3-3-7 -Albatron 5900PV @ 560/1000 -SB Audigy -Adaptec 1210SA Raid -2x120G Seagate SATA150 7200.7 Raid0 -Enermax 460watt psu
