How bad is Hynix DDR for a 9800pro?
(sigh)...I ordered a Saphire 9800 pro from NewEgg expecting to get one with Samsung RAM and I just opened it up...Hynix. What gives? I thought Saphire made all their cards with Samsung. So how bad is Hynix? I've heard it's not as bad as the Infineon. How close does it rate to the Samsung? What kind of overclocking can I expect?
<font color=blue>Asus P4P800 Deluxe, 2.6C @ 3.25Ghz, 1GB Geil Platinum PC4000, Antec TruePower 430, Swiftech MCX4000 w/Sanyo Denki 92mm - 26 deg idle.</font color=blue>
48 answers Last reply
More about hynix 9800pro
  1. Hynix will run at its rated frequency no problem, that's something Infineon cannot do, while Samsung will run far beyond its rated frequency. If your Hynix ram's 2.8ns, then expect it to go about 355-360, probably not much more, Infineon on the other hand the 3.0ns has trouble running at 330mhz.
    <A HREF="http://forums.extremeoverclocking.com/myrig.php?do=view&id=17301" target="_new">My PC</A>
  2. nowhere on my card does it say "saphire." Did I get ripped off? How do I know it's a saphire?
  3. I agree with that any Samsung ram loves voltage, I had some PC2700 Samsung ram, from rated 166, went up to 234 absolutely stable at 3.1Vdimm, i admit it died in about 4 months, but it was a worthy 4 months. Surprisingly it liked to run at the timings of 2.5-3-3-6 than any other timings.
  4. Ok, so what are my options? Should I just accept the fact that I won't be able to overclock, or should I find a way to get a card with Samsung DDR? I just bought a VGA silencer off of ebay and I want to make the most of both!
  5. I was also pissed to get Hynix on my Sapphire 9800P but now I run it stable at 385, and that's after I had very little problems at 390, I just decided to not take any risks.
    Core is at 415.
    Abit IS7 @ 275 FSB, OCZ PC4200 RAM @ 550Mhz, P4 2.4 @ 3.3Ghz Vcore @ 1.625, Sapphire Radeon 9800P @ stock, for now.
    Thermalright SLK-947U, P3 HS @ NB.
  6. Will heat spreaders help here or is it a voltage thing?
  7. I don't know if it's considered hot because I have to way of measuring it, but I can just barely put my finger on the memory chips, any hotter and I wouldn't be able to hold my finger to them for more than a few seconds, that's just a bit cooler than the stock heatsink at 415 MHZ core.
  8. well, at least I'm not alone in the world of Hynix cards. I think my buddy got a Radeon 9800pro with his new Dell system and I'm almost positive he's got Samsung DDR. I know he's not into the OC thing so you guys think I should trade him? There's no difference between Hynix and Samsung at stock speeds, right? Here's another thing: What would I be better off with, a 350 core with Samsung DDR or a 360 core with Hynix?
    <font color=blue>Asus P4P800 Deluxe, 2.6C @ 3.25Ghz, 1GB Geil Platinum PC4000, Radeon 9800 Pro, SB Audigy 2, Antec TrueBlue 480, 2x120GB Maxtor DM+9's: 1 SATA, 1 PATA, Plextor DVD+RW, Plextor CD-RW.</font color=blue><P ID="edit"><FONT SIZE=-1><EM>Edited by krazynutz on 04/25/04 05:49 PM.</EM></FONT></P>
  9. I got hynix RAM with my 9800pro aswell, it sucks. Btw we need to compare benchmark results some time! You practically own my system.
    P4c 2.6@3.25
    512Mb PC4000
    2x120Gb 7200.7 in RAID0
    Waterchill KT12-L30
    Abit AI7
    Radeon 9800Pro
  10. OK, Jammy, from what I remember from friday, these are ballpark figures:
    <b>UPDATE: these are the real numbers now.</b>
    <b>3DMark2001se: 18553
    PCMark2002:
    CPU - 8102, MEM - 10417, HDD - 1414
    3DMark2003: 5828
    PCMark2004: 5146
    AquaMark 3: 44544
    Sandra:
    CPU: Dhry - 10127, Whet - 4118/7191,
    MEM: Int - 5767 Float - 5754</b>
    I think you said that you're from the UK. Your screenname reminds me of something Eddie Izzard would say...lol...
  11. dah...my friend's paranoid about his warranty with Dell if we swap out cards. Said he's sure that the guys at Dell would know specifically what card they put in his machine. Does he have reason to worry or is it just good old fashioned paranoia?
  12. I wanted to flash my BIOS to the 9800XT but it is impossible to get a BIOS for Hynix RAM. I dunno if it would be able to take the speeds anyway. I will try and benchmark my system tonight and will give you the results..I think you beat me in aquamark though...damn u :smile:
    Are you from the UK aswell?
    P4c 2.6@3.25
    512Mb PC4000
    Waterchill KT12-L30
    Abit AI7
    Radeon 9800Pro
  13. yeah, I dunno if I'm even gonna try to overclock it. I'd just get depressed. Anyway, nah, I'm not from the UK. I'm a Yankee over in New Jersey. But I still think Eddie Izzard's funny as hell. I think Hynix DDR is made of jam...
    I'll post my accurate scores tonight when I get home.
  14. UPDATE: Jammy, look a few posts back, I updated my scores to the read deal. There ya go...
  15. Ok here are my results for PC mark 2002:
    CPU - 8099
    RAM - 9846
    HDD - 1668 (bit dissappointing, think i need to defragment)
    I ran aquamark not long ago and I think I got about 42,000 so your system seems to beat mine...dammit. Its your motherboard based on the 875 or 865 chipset?
    P4c 2.6@3.25
    512Mb PC4000
    Waterchill KT12-L30
    Abit AI7
    Radeon 9800Pro
  16. His board's I865PE with PAT enabled.
    hehe, i beat both of you with my little Athlon64.
  17. What scores you getting? I need to run it a few times and take the average at some point, but i cant be bothered atm.
    P4c 2.6@3.25
    512Mb PC4000
    Waterchill KT12-L30
    Abit AI7
    Radeon 9800Pro
  18. "little" Athlon 64? Now that's an understatement. That, and your vid card's overclocked, right? You do have a sweet little system there scotty. And Jammy, yeah, 865PE chipset with Asus's PAT workaround enabled. Ya know, I was gonna do the RAID thing but decided against it. You may be disappionted, but you beat my ass. What about 3DMark scores? 01 & 03? What's wierd is, when I had just 512MB of that Geil DDR, my PCMark2002 Mem scores were around 9500. Then I put the full 1GB kit in and almost get an extra 1000 points. Maybe my 512 kit was kinda crappy...
    <font color=blue>Asus P4P800 Deluxe, 2.6C @ 3.25Ghz, 1GB Geil Platinum PC4000, Radeon 9800 Pro, SB Audigy 2, Antec TrueBlue 480, 2x120GB Maxtor DM+9's: 1 SATA, 1 PATA, Plextor DVD+RW, Plextor CD-RW.</font color=blue><P ID="edit"><FONT SIZE=-1><EM>Edited by krazynutz on 04/27/04 07:07 PM.</EM></FONT></P>
  19. I'm getting around 50000 @ 2300mhz with vid running at 530/975. I'll run it again sometimes tonight, and i'll post a link.
  20. <A HREF="http://arc.aquamark3.com/arc/arc_view.php?run=1150571168" target="_new">This is with vid at 530/975</A> guess i'm 439 marks away from the 50000 mark, have to turn GPU up to 570 and mem to 1G, but that requires fan on highest RPM, that's like triple the noise, for about extra 1500 marks. Not worth it.
  21. Is it worth increaseing the speed of my GPU if I dont increase the speed of the RAM aswell? Just out of interest.
    P4c 2.6@3.25
    512Mb PC4000
    Waterchill KT12-L30
    Abit AI7
    Radeon 9800Pro
  22. Yes, you don't have to syncronise the clocks, you get performance boosts in different areas.
  23. Hey Jammy, wanna see how far our cards will go? Hey scotty, how can manufacturers tell if you've overclocked your video card? I'm sure you've gone through your share. Did you overclock and kill any, and still get the warranty RMA replacement?
  24. Well I haven't dealt with manufactures much, my 9800pro went very well with ATI, and other 9800pro went very well with Gigabyte. Both were overclocked the sh*t out of. Both got killed, but ATI, Gigabyte didn't seem to care at all. Now i deal with distributor which makes my job hella lotsa easier, they don't care at all, they just send me a new one, and i just have to send them my old one within like a month.
  25. Well, I have a Saphire card, so do I RMA (if I ever need to) through ATI or Saphire?
  26. You bought it from newegg right?
  27. yeah, I bought it through newegg, but I doubt the card will go bad in 30 days, so I was asking, say, 6 months down the line or so.
  28. I don't think Sapphire does warranty directly, I think you have to go through newegg, I'm personally not sure with OEM products. And don't use Sapphire's tech support phone, they charge like 3 dollars per minute.
  29. I wonder if ATI would do it. They have a trade-in/upgrade program and they include 3rd party manufacturers, not just "made by ATI" cards.
  30. No ATI would not do your warranty, but if you're trading up they don't care what card you send in.
  31. I will try overclocking my core, but I know the RAM cant go very high. Has anyone changed the cooling on thier radeon9800pro? Did you take the shim off? I have read a lot of posts saying the shim prevents good contact with the core, should I remove it?
    P4c 2.6@3.25
    512Mb PC4000
    Waterchill KT12-L30
    Abit AI7
    Radeon 9800Pro
  32. I'm actually curious of the same thing. I just put on a VGA silencer on mine right now and was curious about the shim myself. The instructions don't mention anything about it so I left it on. So should it be taken off? I've gone to a couple sites that do the installation walk-through and they don't mention removing the shim either. I'm pretty sure mines made good contact with the shim on, AND it protects the core from getting cracked.
    <font color=blue>Asus P4P800 Deluxe, 2.6C @ 3.25Ghz, 1GB Geil Platinum PC4000, Radeon 9800 Pro, SB Audigy 2, Antec TrueBlue 480, 2x120GB Maxtor DM+9's: 1 SATA, 1 PATA, Plextor DVD+RW, Plextor CD-RW.</font color=blue><P ID="edit"><FONT SIZE=-1><EM>Edited by krazynutz on 04/28/04 11:48 PM.</EM></FONT></P>
  33. UPDATE1: Yeah, I've got a good connection. My VGA silencer HS is pretty warm.
    UPDATE2: WTF!! I overclocked my GPU to 410 and got snow in the water on Nature. Had to back it down to 400. I have the VGA silencer. Shouldn't I at least get to 430 or something? Anyway, I have my DDR up to 355(710) and everything seems OK there. Didn't want to push it until I get ramsinks....if they're even worth it at this point. My GPU pisses me off...
    3DMark03: 6130
    AquaMark3: 46452
    Did I get a crap card?
  34. Yes... it's a crap card, now volt mod it.
  35. I have the 360 core. By default, shouldn't this thing do XT GPU speeds without a problem?
  36. Well, no they run at different voltages, so... If I were you i wouldn't overclock that memory after some serious burn-in, you kill the ram very very quickly if you start off overclocking the crap out of it without burning it at its rated speeds. You could try raising the VAGP a little, see if it helps.
  37. Yeh raise your AGP voltage to about 1.6v, I had the same prob on mine but when I raised the AGP voltage the snow went.
    P4c 2.6@3.25
    512Mb PC4000
    Waterchill KT12-L30
    Abit AI7
    Radeon 9800Pro
  38. wow, thanks guys. So what do you have your card up to Jammy?
  39. Ok my core is stable at 400Mhz with 1.65v AGP. Anything higher than that and I get snow in 3D marks nature test. Damn R350 core. The RAM is not as bad as I thought, ran fine a 365Mhz, got it up to 380Mhz but it felt very hot so Im gonna get some BGA ramsinks before I go any higher.
    At 400core and 365RAM Im getting about 45,000 in aquamark and about 6100 in 3D mark...not bad.
    You had any luck with your card?
    P4c 2.6@3.25
    512Mb PC4000
    Waterchill KT12-L30
    Abit AI7
    Radeon 9800Pro
  40. £20 for fecking ramsinks! You have to be sh*tting me!
    Does anyone know anywhere in the UK that sells BGA ramsinks that are cheaper then £20?
    P4c 2.6@3.25
    512Mb PC4000
    Waterchill KT12-L30
    Abit AI7
    Radeon 9800Pro
  41. Holy Sh!t. Man, that's like $40 over here, isn't it? And I thought $20 USD was bad...man, I feel for ya. I have the 360 core so after I get everything burned in properly, I'll up it again and see how far I can go. I just wanna hit XT speeds and I'll be happy. I think I'm gonna get the OCZ ramsinks. More surface area and all copper.
  42. So what's a better combo? A 350 core with Samsung DDR, or a 360 core with Hynix?
  43. interesting. Is it because you can push the core further? Do you get more of a gain from core overclocking or DDR overclocking?
  44. dude, I can't get my core past 414 without issues in ATI Tools. Even there, I get trace amounts of snow in the water in Nature. I have to back it down to about 400-405 to be completely snow-free. I'm supposed to have a 360 core. Plus I have a VGA silencer on it. Any ideas what might be wrong here? I even upped my voltage to 1.6. Didn't make a difference.
  45. Ok, the 4-pin power plug that you plug into the card - is it OK to have other things on that line or should the video card be the only thing on it? Also, what you said about the default VGPU - is that a mobo issue or a video card issue? If I check and double-check all possibilities of bad cooling and it turns out I have a crap chip, is that enough to RMA and get a new one? What would be my best option at that point?
  46. No, BBA puts samsung chips on all their 9800 pros. OEMs put watever they feel like or watever is in grabbing range.
    Mobile Barton 2500+ @ 2420mhz 11x220 1.7v
    Asus A7N8X Dlx 440 FSB
    1gb Geil GD pc3500 Dual Channel (2-3-3-6)
    Segata 80gb SATA 8.5ms seek
    ATI Radeon 9800 Pro(420/730)
  47. I too bought a dell with a BBA 9800 pro in it and it came with samsung memory. i would be OC'ing the hell out of it, except for the utter lack of ventilation the dell system has. as soon as i can afford a VGA silencer, ill see what i can get mine up to =)
  48. You can find 'em cheap on ebay or <A HREF="http://www.frozencpu.com/cgi-bin/frozencpu/vid-21.html" target="_new">here</A>. Bought mine off of ebay. unopened retail packaging. Good luck if you bid.
Graphics Cards Hynix Samsung Overclocking
