hi i'm trying to put together a water cooling set for an overclocked athlon xp 2400+, not sure yet how much it will actually be overclocked to and remain stable at. but i've been thinking about the following components for water cooling:
radiator: 1x120mm or 2x80mm black ice ?
pump: eheim or swiftech pump for 300+ gph
water block: something from swiftech
also i'm wondering whether to put the radiator outside the case for better cooling performance but more noise
any bit of help, suggestion, input will be much appreciated
thanks
thanks
