I was wondering if someone around here has any experience with WATER COOLING systems, and if someone does, what do you recomend for a AMD ATHLON XP 3200+ ? not overclocked or anything, Whats the best kit out there? thanks
Are you a beginner when it comes to watercooling systems? If so I would recommend the Asetek water cooling kits, they are really good performers and are easy to install (comparitivly speaking).
Go here <A HREF="http://www.waterchill.com" target="_new">http://www.waterchill.com</A>
I have always been a fan of innovatek products. They have far superior methods of hose attachment at least in my mind. They are a little more complicated to install but are much better in the long run. They sell box sets and individual components. Most Innovatek products can be found at sharkacorp.com and frozencpu.com. I have built 3 systems with all innovatek parts and I have never had any issues with them.
You'll find my Asetek and Zalman reviews at <A HREF="http://www.sysopt.com" target="_new">http://www.sysopt.com</A>
<font color=blue>Only a place as big as the internet could be home to a hero as big as Crashman!</font color=blue>
<font color=red>Only a place as big as the internet could be home to an ego as large as Crashman's!</font color=red>
I have a XP3200+ cooled by a Innovatek rev 3 CPU cooler (chip and GFX is also Innovatek), Maxx radiator and a papst fan, it is installed in a midi tower so I had to place the radiator in the front (blowing hot air into the case), but it still keeps the CPU below 50 C, and it is noise less !!!! - try Innovatek you can't go wrong with that
