Water cooling for Gfx card only?
August 17, 2004 5:55:52 AM
Any one know where i can find a small water cooling set up for my Gfx card only? something simular to what comes with the gainward 6800 ultra?
<A HREF="http://arc.aquamark3.com/arc/arc_view.php?run=682299587" target="_new">40k in aquamark 3
</A>
P4b2.4@2.8||1024mb DDR@392mhz||9800pro@420/740||Viewsonic UltraBrite 19"||Panisonic DVD-RW
More about : water cooling gfx card
August 18, 2004 5:33:08 AM
Any one know if such a thing is out there or should i just get a reg watercooling setup.
</A>
August 18, 2004 10:54:47 AM
Why dont you just get the gainward one? Otherwise I think you will have to get the parts seperatly. Hydor L20 pump, 80mm radiator and a good waterblock and you are sorted.
