Powerful cooling solution to make a GT run at Ultra speeds without worries, <b>since thats what they guarantee</b>
Who guarantees? I'm sure Gainward doesn't say it will run Ultra speeds are they return it?
Anyways, Gainward does have a better heatsink than most.
Never owned a Gainward, so can't say anything about them.
Have owned two LeadTeks so far, and can say nothing but positive things about their heatsinks.
Personally I'm still in favor of the LeadTek card, its heatsink is larger. The gainward is tall because of the fans, the LeadTek is just huge, even though it only has one fan, vs. two that the Gainward has. You need surface area to dispate heat, and the LeadTek has much more surface area exposed to air than the Gainward.
Also the Gainward has to use the adapter to plug in a regular monitor, though this isn't any sort of big deal, I personally don't care for this. I never can seem to get the adapter screwed on there tight enough, to hold the monitor plug solid, it always seems to hang down a little, though not a big deal, it bothers me.
However, you may want to go with the Gainward, sounds like you have talked to enough people who know for a fact that it will do what you want, and that is what is important.
My Desktop: <A HREF="http://Mr5oh.tripod.com/pc.html" target="_new">http://Mr5oh.tripod.com/pc.html</A>
