Hello,
I have been looking for the past two weeks for a Full-HD monitor to replace my old CRT TV. I know absolutely nothing about monitors
I will use it entirely and solely for playing the PS3 on
I have been told that ASUS are my #1 destination and, as such, I have found these two monitors from ASUS
http://www.asus.com/Monitors_Projectors/VG248QE/
and
http://www.asus.com/Monitors_Projectors/VG23AH/#overview
Are they good to play the PS3 on? Or are there better alternatives (Even if from other brands)?
What I'm looking for is the following:
- 23~34 inch in size
- LED
- Full HD 1920 x 1080
- Can listen to the audio using headphones
- Adjustable (If possible)
- HDMI slot
PS: My budget is a maximum of 300$
and
- LED
- HDMI slot
