Tom's Hardware > Forum > Systems > Gateway2000 > Power Supply ?
Archived from groups: alt.sys.pc-clone.gateway2000 (More info?)
Greetings,
I have an older Gateway (several years old). The power supply has
decided to 'not play nice'. Can I just get a standard ATX power supply,
or is there something different about the gateway power supplies ?
thanks,
Darryl
Sponsored Links
They are pretty much standard. Just get the physical measurements and
layout (fan, cable and mounting screw holes) and get one of the proper
layout and power rating.
"Darryl" <darryl@osborne-ind.com> wrote in message
news:0uSdnbm7B-Uk8VrdRVn-ig@news.ruraltel.net...
> Greetings,
> thanks,
> Darryl
Reply to Anonymous
- 0 +
I can tell you for sure that if your case is the one pictured below a
standard ATX will fit since I just replaced mine in the same case:
http://cgi.ebay.com/ws/eBayISAPI.d [...] 44382&rd=1
And that case uses the clip so screw holes didn't even matter.
Smith
> Greetings,
> thanks,
> Darryl
Reply to smith
There are 1028 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
