Someone told me the other day that since distilled water is used in water cooling systems, it dosen't matter if it gets on your components: they will just get wet but no damage will occur.
Technically true. But I wouldn't try it, as any liquid could mess up the electrical connections.
______________
OK it's your choice:
You can have the boat, or you can have the Mystery Box!
...Hey wait a minute! A boat's a boat, but a Mystery Box could be anything. It could even be a boat
Mineral oil will not hurt the capacitors at least in the short run. I have tried it myself. As for the distilled water, you are correct about the corrosion and/or oxidation. Distilled water is fine unless it gain properties from other components. So basically it would be fine at first, but not after it reacts with the metal of the heatsink.
No, I just got a digital cam a couple of days ago. If you could PM me that website that you told me about I will get some pics up. Can you put video clips in the website also?
Well said! Another negative with distilled water is that from what I have been told, if the system isnt totally free of impurities "cleaned" the distilled water will rapidly build up its abiltiy to conduct electricity. Organisms will also begin to grow if something isnt added to it. I use distilled water myself, but I always put a touch of additive to it.
As long as you do everything carefully and meticulously, water cooling is not dangerous. It's just as safe as air cooling. You just can't cut corners. And you need to plan ahead.
what site? I need some webspace for my pics. Image shack is annoying.
______________
I thought that Folken was the one that had told me about a site, but I had him mixed up with someone else. In other words I dont know. Im setting up an old P550 as a server, Folken has a server that is similar to the one im putting toghether.
