Gents,
I came up with the build below using cyberpowerpc.com. I'm not a hardware expert by any stretch, particularly when it comes to gaming components, and need some advice. What do you think of the build? Am I overweight one set of components at the expense of another? I am OK with the price but probably can't go any higher, so extras will likely require a tradeoff. Also, I'm not thrilled about building instead of buying pre-built but could be swayed if the cost advantage was sizeable. What would you expect...$100? $200?
Thanks for the help.
Product Name: Gamer Infinity 8800 Pro
Price: $1,801.00
______________________________________________________________________
*BASE_PRICE:[+1309]
BLUETOOTH:None
CARE1:Ultra Enhanced Packaging Solution - Protect Your Dream System During Transit [+19]
CAS:Cooler Master HAF XB Gaming Case w/ Removable Motherboard Tray, Front USB 3.0 x2, HDD Hot Swap & X-Dock
CASUPGRADE:None
CD:24X Double Layer Dual Format DVD+-R/+-RW + CD-R/RW Drive (BLACK COLOR)
CD2:None
COOLANT:Standard Coolant
CPU:Intel® Core™ i7-3770K 3.50 GHz 8MB Intel Smart Cache LGA1155 (All Venom OC Certified)
CS_FAN:Maximum 120MM Case Cooling Fans for your selected case [+9]
ENGRAVING:None
ENGRAVING_MSG:
FA_HDD:None
FAN:Asetek 510LC Liquid Cooling System 120MM Radiator & Fan (Enhanced Cooling Performance + Extreme Silent at 20dBA) (Dual Standard 120MM Fans (Push-Pull) [+9])
FLASHMEDIA:None
FREEBIE_MB:None
FREEBIE_VC:None
FREEBIE_VC2:None
GLASSES:None
HDD:128 GB OCZ Vertex 4 SATA-III 6.0Gb/s - 535 MB/s Read & 200 MB/s Write [+31] (Single Drive)
HDD2:1TB Western Digital Caviar Blue SATA-III 6.0Gb/s 7200 RPM HDD [+94] (Single Drive)
IEEE_CARD:None
IUSB:Built-in USB 2.0 Ports
KEYBOARD:AZZA Multimedia USB Gaming Keyboard
MB_SRT:None
MEMORY:16GB (4GBx4) DDR3/1866MHz Dual Channel Memory [+108] (Patriot Viper III [+19])
MONITOR:* 24" Widescreen 1920x1080 ASUS VS247H-P LCD [+157]
MONITOR2:None
MONITOR3:None
MOTHERBOARD:[CrossFireX] GIGABYTE GA-Z77-HD3 Intel Z77 Chipset DDR3 ATX Mainboard w/ IRST, Ultra Durable 4 Classic, 7.1 HD Audio, GbLAN, 2x Gen3 PCIe x16, 2x PCIe x1 & 2 PCI (Extreme OC Certified)
MOUSE:AZZA Optical 1600dpi Gaming Mouse with Weight Adjustable Cartridge
NETWORK:Onboard Gigabit LAN Network
OS:Microsoft® Windows 8 Pro (64-bit Edition) [+31]
OVERCLOCK:No Overclocking
POWERSUPPLY:800 Watts - Standard 80 Plus Certified Power Supply - SLI/CrossFireX Ready
RUSH:No Rush Service, Estimate Ship Date 10 Business Days
SERVICE:STANDARD WARRANTY: 3-YEAR LIMITED WARRANTY PLUS LIFE-TIME TECHNICAL SUPPORT
SOUND:HIGH DEFINITION ON-BOARD 7.1 AUDIO
SPEAKERS:600Watts PMPO Subwoofer Stereo Speakers [+15]
TABLET:None
TEMP:None
TUNING:None
TVRC:None
USB:None
USBFLASH:None
USBHD:None
USBX:None
VIDEO:NVIDIA GeForce GTX 660 2GB 16X PCIe 3.0 Video Card (Major Brand Powered by NVIDIA)
VIDEO2:None
VIDEO3:None
WNC:None
_PRICE+1801)
Price: $1,801.00
*BASE_PRICE:[+1309]
BLUETOOTH:None
CASUPGRADE:None
CD2:None
ENGRAVING:None
ENGRAVING_MSG:
FA_HDD:None
FLASHMEDIA:None
FREEBIE_MB:None
FREEBIE_VC:None
FREEBIE_VC2:None
GLASSES:None
IEEE_CARD:None
MB_SRT:None
MONITOR2:None
MONITOR3:None
TABLET:None
TEMP:None
TUNING:None
TVRC:None
USB:None
USBFLASH:None
USBHD:None
USBX:None
VIDEO2:None
VIDEO3:None
WNC:None
_PRICE+1801)
