Is there any reason why my motherboard (Asus P4S800D-E Deluxe) won't sense the speed of either of two Panaflo (FBA08A12U1A) fans? I've tried connecting both directly to a three pin connector on the board and using a 3-4 pin adapter with a speed sensing thing, but in both cases, I've had no luck getting it to work right.
Also, I was a bit suprised to find that just one of these Panaflos on my Hyper6 makes significantly more noise than the cheap Coolermaster fan that came with the heatsink. Even stranger, my CPU temp is slightly higher using 2 Panaflos than it was using the single Coolermaster fan...and the Panaflos are rated as much more powerful.
