Low FPS Issue. Please Help.
ZzAsh92zZ
Not sure if this is in the right place as its my first post but here's the question.
I have a low FPS when playing games. I get a solid 60 FPS on the menu screens.
But when starting the game, the loading screen again gets a solid 55-60 FPS but as soon as the game loads it goes to around 15 FPS and stays there. I don't know if this is causing the lag in game, not lag like jumpy but more input lag. I will move the mouse and about half a second to a second later the wheel (or whatever game I'm playing) will turn.
The main thing that has got to me is that I never had this problem before I had to re-installed windows (another problem nothing to do with gaming, now fixed) and I had no lag or low FPS.
I have tried updating the graphics driver, updating BIOS, reverting back to the drivers on the disk which I had installed before re-installing windows and another seems to be fixing the problem.
The computer is about 2 months old so there shouldnt be a problem with any of the hardware, unless I damaged something when installing 2 case fans.
My computer specs are:
AMD FX-8350 Eight Core CPU (4.00GHz/8MB CACHE/AM3+)
ASUS® SABERTOOTH 990FX R2.0 (DDR3, USB3.0, 6Gb/s, CrossFireX/Sli)
8GB KINGSTON HYPERX GENESIS DUAL-DDR3 1866MHz X.M.P(2 x 4GB KIT)
1GB AMD RADEON™ HD7750 - DVI,HDMI,VGA - DX® 11
120GB KINGSTON V+200 SSD, SATA 6 Gb (535MB/R, 460MB/W)
1TB 3.5" SATA-III 6GB/s HDD 7200RPM 32MB CACHE
CORSAIR 650W ENTHUSIAST SERIES™ TX650 V2-80 PLUS® BRONZE
Super Quiet 22dBA Triple Copper Heatpipe AMD CPU Cooler
Thanks in advance
ZzAsh92zZ
Also to note, reducing the graphics to low fixes the problem. But it used to run it on ultra settings so I know the graphics card/my computer can run the game.
