I would like to know what additive I should use? swiftech/innovatek/other.
this is with the Zalman Reserator1, zm-wb2 gold block for the cpu, and a nv40 cooler by innovatek. for the video card.
Also should I replace stock water pump in the Reserator1?
Ok, so a bigger pump.
I'm planning to split the water line in/out and go to both the cpu and video card at the same time using a set of Y's
good/bad idea.
Reducing the flow rate is always a bad idea, and I recommend strongly against it since it reduces overall load performance, during idle it'll run cooler but on load both components will run hotter. As for the pump I don't know, the reserator pump isn't all that bad it's pretty decent, compared to 12v pumps. I'd keep it if I were you, the only thing I'd do is to buy a house fan and blow towards the massive passive radiator.
agreed, because water itself can contain massive amount of energy, it'll be useless to split the gfx and the cpu blocks. also, most pumps won't have enough flow/head pressure to support this setup sufficently, if ur running the iwakis, then i guess your fine to some degree, but i still go against it. also dude, hows the reseator compared to two double heatercores in series?
Well reserator is good for what it is, absolute silence, but I still prefer extra huge radiators or heatercores. The large radiators and heatercores that uses 4x120mm fans are better than the reserator, of course for people who are into modding, vehicle radiators are much better.
ermm.. i don't have a bix.... explain your point? and there are alternatives that the other dude should look into, there's zerez(auto racing liquid), inovatec pro fluid, swifty pro, danger den. i'm saying those are other options, but i personally would still go with the water wetter..... depends on your needs.
Yes they do that's where I got mine, don't go online to those so called "watercooling specialist" stores to buy their additives, they're just rip-off's.
