Tom's Hardware > Forum > Systems > Gateway2000 > solo 2150 cmos battery replacement
Forum Systems : Gateway2000 - solo 2150 cmos battery replacement
Archived from groups: alt.sys.pc-clone.gateway2000 (More info?)
Hi,
I am going to have to replace a dead cmos battery in a friends solo 2150
laptop. I have searched the net with no luck for disassembly instructions. I
haven't got to see the laptop yet, but I would like to know what I am up
against. Has anyone in this forum taken apart a 2150? Is it straight forward
or are there 'hidden' screws and stuff?
I love laptops but desktops are so much easier to work on.
Than you,
Yvonne
Sponsored Links
Yvonne <yvonnehannaathotmail.com> wrote:
: Hi,
: I am going to have to replace a dead cmos battery in a friends solo 2150
: laptop. I have searched the net with no luck for disassembly instructions. I
: haven't got to see the laptop yet, but I would like to know what I am up
: against. Has anyone in this forum taken apart a 2150? Is it straight forward
: or are there 'hidden' screws and stuff?
: I love laptops but desktops are so much easier to work on.
: Than you,
: Yvonne
I think the cmos battery is under the keyboard on the 2150. The keyboard
is held in place by tabs around the keyboard frame. You will need to use a
jeweler's screwdriver or similar small flat instrument to gently pry the
keyboard up. There is a gateway laptop forum at
http://www.voy.com/56937/
It has a lot of helpful info on the 2150.
Reply to Anonymous
- 0 +
Thank You !
Yvonne
<kmy@hiwaay.net> wrote in message news:10e06ni5mahiu59@corp.supernews.com...
> : Hi,
instructions. I
forward
> : Than you,
> : Yvonne
Reply to yvonne
There are 1263 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
