did u also remember how loud ur psu had to work to get hot ait out the case.
i would recommend water cooling to any1 excpecially since its so cheap to get hold of a kit theres no excuse.
i cant believe the difference i got myself the Asetek WaterChill Antarctica KT12A-L30 CPU/VGA/Chipset TRIPLE RAD POWER KIT
WoW ultra silent pc now the only noise coming from the computer is the whirring of the slow spinning 80mm fans in the psu thermaltake butterfly 480watt.
OC the cpu goes a lot further now, betta than the TT bigwater but i am not putting that down the tt bigwater is excelent at keeping it silent.
what is everone elses opnion on the water cooling setup to there old air cooler setup?
<font color=purple> MY FINGER IS ON THE BUTTON! </font color=purple>
Watercooling was fine... just wasn't cutting the cooling I need, I don't trust peltiers cooling my components that much after it KILLED MY FX5900!
I can't believe you actually bought that, how much did it cost you? a good 300US at least? You could've saved so much money if you just paid a visit to a junkyard for a radiator, and went to Wal-Mart for a pump. You could make your own waterblocks, but I don't recommend it, so you buy the waterblocks, CPU/VGA, and HDD if you have Raptor or 15000rpm+ SCSI drives. I really don't recommend chipset blocks, since a Vantec Iceberq4 does the job really well.
So yeah just my opinion if you're going to spend that much money on a watercooling setup, the triple radiator... lol i'll bet ANY car radiator will beat that thing's performance, well i guess car rads are huge and weighs a crapload. Anyways, if you're going to spend that much money on watercooling setup, might as well save a tiny bit more for a prometeia mach2 ls.
But still that kit's great, you should buy another XP120 with a Silverstone 120mm fan, and a 226watt peltier. Epoxy the peltier on the radiator, I said I don't trust peltiers on components(GPU/CPU) But I trust it on radiators since it'll just make the water cooler. Then use the XP120 to cool the peltier.
I have 2 Cheetahs(Seagate 15000rpm) for a while now on an Adaptec SCSI raid controller And no they're not watercooled, got those Vantec dual fan thingy cooling it.
i dont think i be needing the pelter, i live in england and its freezing here it was snowing yesterday (its 2.30 am so 2 days ago) and this takes me onto my second mod i did with my window in my bedroom.
my window is constructed of UPVC White in colour and a aluminium frame inside the upvc frame e,t,c
i drilled two 1/2 holes througth the frame then swirled the drill to make the holes slightly bigger, then i made a white upvc box which could house the triple radiater and made it weather proof with some silicone bath sealer, the power wire was easy to feed through the window with the speed controler wire, the window shuts perfictly, i fed the tubes through the frame attached the tubing to the radiaters connected all together and presto.
Super out door cooled radiaters and ultra silent, note extra tubing was needed and the wires had to be cut and extended so soldering required and it does help when ur pc is next to the window.
outside temp at night is 2-4 C and day time is 14 C approx, my cpu is usally cooled to 20 C and below and so is the GRFIX and MB. nite time it goes down to 11C approx or below and all ran at minimum speed on fans.
cant wait until it goes below freezing point outside then i be pushing higher OC`s but one problem my psu seems to be stuggling to provide power my 12volt rail seems low its at 11.7 to 11.6 it keeps fluctuating all other rails are GOOD its a 480watt TT butterfly.
Water cooling can make motherboard components overheat. What, you thought the CPU fan was only for the CPU cooler? Hehe, I added a 50mm fan to my chipset sink after that got scalding hot. Of course I modded it for 7v, so I wouldn't hear it. And what about the CPU voltage regulator?
<font color=blue>Only a place as big as the internet could be home to a hero as big as Crashman!</font color=blue>
<font color=red>Only a place as big as the internet could be home to an ego as large as Crashman's!</font color=red>
Kind of defeats the purpose of using water cooling for silence, eh?
i have the xaser III case it has 4 silent fans which circulate air, NO matter what you have you always need good airciculation for the capaciters e,t,c on the MB and for the psu.
now that i have no hot air from the cpu in my case my psu is silent i have a steady hum coming from the fans which are all whirring at 1000- 1200 rpm which is sub 20db.
this for me is silent and really silent as my 3 120mm fans for the triple radiater are outside the house on the window sill.
so silent i have. and air circulation i have too, you think i am going to spend £200 for water cooling and let my MB burn out?
good air ciculation = silent psu = steady comp = silent comp = ?
i havent pushed volts too high yet i want reliability i have ran out of money, spent £200 water cooler and £350 on 19inch tft L90D+ hyundai 8ms moniter, so i cannot afford to blow sumthing up yet wife will kill me.
Well silence, if you use a whole bunch of fans then turned down using a fan controller, you can keep the noise down pretty low, as for motherboard overheating, I don't know about that, I mean with watercooling, you take the heat of the CPU and GPU to outside of the case if you're using exterior mount of radiator which I highly recommends. So with the 2 major heatsources taken to outside of the case, the case interior temp will drop, and I think that really helps to cool motherboard components.
No, in fact, the opposite is true. After moving the heat from the CPU and GPU to an external radiator, I found my northbridge (large passive cooler) was SCALDING HOT! The only case ventilation was an 80mm fan at the hard drives, turned down using 7v.
The parts around the CPU RELLY on the CPU cooler to circulate air over them. A side fan on the case would do the trick, but the thing is, removing the CPU heat from the case doesn't do crap for the stuff around the CPU.
Case fans remove heat too. But even with my case wide open my passive northbridge cooler was scalding hot: It relies on the CPU cooler. And without that, I was forced to mount a fan.
For me it was totally the opposite of what you just experienced, i've got the Temjin06 case, and the casefans blows directly on the cpu and surrounding region of the motherboard, the power regulator's temperature reduced from 96C down to 57C, oh wait that could be because of the prometeia Mach 2 I got freezing the surrounding area.
You're using a case fan to cool it, one that's in the same vacinity as the CPU fan would have been.
My side fan would be aimed at the underside of the video card, if I used it.
Yes, the last picture shows my homemade power supply (in an old Spakle Power casing), the CPU and VGA water blocks, and my 50mm CPU fan (wired for 7v) attached to the previously passive chipset cooler.
Yes water cooling is great. In my experience I needed to do a little more to the cooling than just put a pump and rad in. I had found that even after putting in a new water cooling system I was still running higher than I wanted to so I started looking at chilers. I built a chiller and got rid of the fans. My external temps are below the 0 mark and I have one fan for air flow so if you do go water don't be shocked if you too some day will be looking at a chiller.
