I decided to go for a 64bit processor, mainly a AMD 3500+ Winchester core. With that, I need a new mobo and decided on the Asus A8V Deluxe. No PCIe since I think I want to keep my 9800XT.
The problem is that since I'm pinching for money and went for a OEM 64bit 3500+ and it doesn't come with a heatsink fan, and probably no retention bracket too. I wanted to get a Zalman CNPS7700 because of obvious cooling performance and noise emission, but I'm afraid of the weight, with 450 being recommended max weight of the HSF for AMD64. Plus for the A8V mobo, Zalman requires the removal of the retention bracket to install the HSF, due to capacitors being in the way. On top of that I'll be moving my computer about every week or so.
Now to the real questions.
I just dont know what HSF I should get, is weight really that big of a problem when moving around, is the retention bracket really that important, or should I just try another mobo?
Its just that I like the Asus features of auto optimizing, setting backups...
<P ID="edit"><FONT SIZE=-1><EM>Edited by isamu966 on 04/10/05 01:33 PM.</EM></FONT></P>
