Tom's Hardware > Forum > Overclocking > Cooler and Heatsinks > cheapest water cooling rig
Forum Overclocking : Cooler and Heatsinks - cheapest water cooling rig
i dont have much money at ALL after i order my parts from newegg. maybe just over $100. not sure if i should wait couple months to get a better water cooled rig.
Sponsored Links
save the money
<font color=red>gforce mx100/200 @ 230/440 =]</font color=red>
Reply to shawnlizzle =]
- 0 +
Save half, send the rest to me.
<pre><font color=red>°¤o,¸¸¸,o¤°`°¤o \\// o¤°`°¤o,¸¸¸,o¤°
And the sign says "You got to have a membership card to get inside" Huh
So I got me a pen and paper And I made up my own little sign</pre><p></font color=red>
Reply to RichPLS
take money with style, c'mon 50 dollars?
Wait for a couple month, or you can always build the hobo's watercooling rig.
You'll need following parts:
1. Gigantic trash can(steal 1 from 1 of your neighbours)
2. Hydor L35($25)
3. Swiftech MCW6002($40)
4. 1/2 Vinyl tubing from hardware shop
This is a good setup, because you can have soo much water, it can cool itself without a radiator.
Reply to scottchen
If you live in a really hot part of the states, then salvage a car radiator from a junkyard, then pick up a second Hydor L35, then link them in a chain, you'll need the extra flow rate.
Reply to scottchen
- 0 +
Cheapest is to use a tub of water, plug in PC, set in tub.
Reply to RichPLS
- 0 +
hobo's watercooling rig.....LMAO
<A HREF="http://www.freewebs.com/lb19984/" target="_new">My Rig</A>
Reply to lb19984
100 bucks that's rough for a watercooled.
Prolly Thermaltake's Bigwater (cl-w0005). $106 off of casemod.com (I've never heard of casemod.com). There are a bunch more retail sites you can find from froogle.
Good luck.
Reply to AngryRaisin
There are 792 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
