Tom's Hardware > Forum > Mobility Networks > Verizon > Any downside to "Leave Bluetooth Power Permanently On" on ..
Forum Mobility Networks : Verizon - Any downside to "Leave Bluetooth Power Permanently On" on ..
Archived from groups: alt.cellular.verizon (More info?)
It's a menu-path pain to get the phone's Bluetooth power on, and I
can't create a shortcut to do it.
1) What does it mean, anyway, to "power on" Bluetooth (on the phone)?
2) There's a setup option to turn the Bluetooth power "Permanently On"
- any reason(s) *not* to do that?
Thanks...
Sponsored Links
I just got off a highly unsatisfactory 10-minute call with Verizon
Tech. Support on this issue. The rep. told me that the on/off
capability was there for people who didn't have a Bluetooth headset.
However, she was unable to provide any kind of a cogent explanation as
to why the option existed at all.
My hunch is that there may very well be a valid reason to turn it off,
but I sure don't know why at this point...
Reply to Anonymous
I believe that leaving Bluetooth on all the time may run your battery down a
bit trying to search for a connection.
<david.f.jenkins@usa.net> wrote in message
news:1120837365.413572.233100@g49g2000cwa.googlegroups.com...
Reply to Anonymous
> with Verizon Tech. Support on this issue. The rep. told
> me that the on/off capability was there for people who
> didn't have a Bluetooth headset. However, she was unable
> to provide any kind of a cogent explanation as to why the
> turn it off, but I sure don't know why at this point...
Battery drain. If you're not using it there is no reason to
waste the battery powering yet another radio transmitter/
receiver and possibly the software that monitors it.
-Quick
Reply to Anonymous
In article <1120824641.113747.19880@o13g2000cwo.googlegroups.com>,
If you have a bluetooth headset or car kit, keep it on so it will always
mate with the headset or car kit.
Leaving it always on, though, uses up power faster than if you didn't.
Stop Mad Cowboy Disease: Impeach the son of a Bush.
Reply to Anonymous
I have a BlackBerry 7250 with Verizon, I leave my buetooth option permanently
on so that I can connect to my bluetooth hadset (which i turn off to conserve
battery on the headset) at will and have had no significant power loss
whatsoever.
----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==----
http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups
----= East and West-Coast Server Farms - Total Privacy via Encryption =----
Reply to Anonymous
It does not search for a signal, it simply responds to one when the headset is
activated.
Reply to Anonymous
I am not sure how much concern to have with Bluetooth and the way VZW
"cripples" it but I read that many Bluetooth phones and PDAs have been
compromised thru a Bluetooth connection. It seems folks load a laptop with
software and a good Bluetooth antenna into a briefcase or backpack, then
visit busy areas. The software searches for active Bluetooth units and
attempts to connect and gain whatever info is held within. From minor
fooling with the setup screen for my V710, I don't see where any old
connection coming by will be accepted... but I'm not using any Bluetooth
right now so I may be a bit confused. I hope this is helpful.
PoD
news:1120824641.113747.19880@o13g2000cwo.googlegroups.com...
> Thanks...
Reply to Anonymous
> one when the headset is activated.
So how does it know when another radio is in range?
-Quick
Reply to Anonymous
> -Quick
If you are on a deivce like a laptop, or PDA w/BT, tell it to search
for items in range. It will then report a list of devices that are
active, and give you the option to pair up with one at that point.
cdawg
Cell Phone Forums: http://cellphoneforums.net
View this thread: http://cellphoneforums.net/t180968.html
Reply to Anonymous
When this point was discussed on HowardForums, the observation was that
for the 710, anyway, turning on the BT menu but not being actively
connected to a device like a headset consumed negligible power. The
reason is that the phone operates in "stealth" (non-discoverable) mode
when not connected to a device; that is, it is never transmitting, and
occasionally very briefly listens (probably along with the check for a
cellular page) for a device transmitting a connection request. There
would be nothing for a BT scanner to see. The 710 does not support any
of the profiles which require a phone to be discoverable by other BT
devices.
Note that there will be a power-consuming BT connection between the
phone and BT device (say, a headset), from the time you tell the device
to connect to the time you tell it to disconnect, even if you never make
any calls.
Reply to Anonymous
CharlesH wrote:
>> to waste the battery powering yet another radio
>> transmitter/ receiver and possibly the software that
>> monitors it.
> observation was that for the 710, anyway, turning on the
> BT menu but not being actively connected to a device like
> a headset consumed negligible power. The reason is that
> transmitting, and occasionally very briefly listens
> (probably along with the check for a cellular page) for a
Ok, just the receiver then. They make the page check
interval configurable too right? I suppose it could have
been in response to the bluetooth hacking hype too.
I'm clueless about bluetooth. What about crowded
areas? If the receiver is in ear shot of a lot of or constant
connection requests isn't it going to do a good bit of
work deciding whether to reject/ignore or not?
-Quick
Reply to Anonymous
There are 1301 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
