Archived from groups: comp.sys.ibm.pc.hardware.chips (More info?)
Guys,
I have 2 Operating Systems on my computer :
First is Windows 2000 Corporate SP4.
Second is Windows XP SP1.
I installed on each 4in1 drivers (VIAHyperion4in1451v.exe)
When I copy a big file (about 100 Mbytes) from the DVD player to one of my
HDD here are the problems :
- With Windows 2000, my USB modem hang up (Alcatel speedtouch USB behind a
USB modem with its own power supply).
- With XP SP1, the computer crash and reboots !!!
I had these problems for 2 years, but now, I need to move from DVD big files
to HDD, and I would like to solve it.
The problem encoutered with XP is not a hardware problem, because it works
with windows 2000.
Config :
Mother Board : ABIT KT7A
Athlon 1,1 GHz
Chipset Via KT133
1 HDD 80 Go Western Digital (Primary Master) 80 pin cable - UDMA 5
1 HDD Maxtor 80 Go (Primary Slave) 80 pin cable - UDMA 5
1 Ricoh DVD+RW (Secondary Master) 40 pin cable - UMDA 2
1 DVD player Hitachi (Secondary Slave) 40 pin cable - UDMA 2
On Sun, 20 Jun 2004 20:37:14 +0200, "tb" <tbeghin@free.fr> wrote:
>Guys,
Many thanks.
I solved these problems by applying the Vlatency 0.19 patch.
Many thanks for the link
"Ed" <uranidiot@behappy.com> a écrit dans le message de news:
vm4cd0p45j4k35poqaaraf44rqs0aj3uou@4ax.com...
> >Guys,
my
> VIA Issues - IDE and SoundBlaster Live, Update 2
> http://www.realworldtech.com/page. [...] 1401003409 >
> search google for "VIA Patch" ?
